My Wife Drove My Truck?!?!?!
I have a 14' All Terrain SLT with the 20" wheels. I had to take my wife's car to the dealership and was forced to let her take my truck shopping for the day. The next day walking out to my truck i notice a nasty gouge in my front left wheel!
Is anyone selling one of these wheels or do you know anywhere to get one that wont break the bank...
Thanks in advance!
And my wife wonders why I don't like her to drive my truck, now she wants us to get a new Vette for a pleasure vehicle and so she can drive it to work. yet her vehicle has 3 out of the 4 wheels with road rash.
This is the best time to pursue new rims and tires without the wrath of an unhappy wife you have already talked to the dealer and the gauges affects the structural integrity of the truck, which could void the warranty. Therefore all four wheels & tires will need to be replaced however there is a shortage of that specific wheel due to labor disputes in Mexico you will need to utilize resources available locally such as tire rack.com or Fletchers
Void the warranty?
Would this be a warranty covered item
I think he is trying to assist you in the story you tell your wife! :happysad:
Ha gotcha!
I actually really like my factory wheels though.
I don't think you can have these wheels repaired since they are chrome finished (?), but I had CCW wheels on my GTO refinished and trued because they had so much rash on them and two had slow leaks. But those are brushed aluminum.
Also on my wife's T/A, one replacement GM stock wheel cost was more than a set of American Racing wheels. So guess what is on her T/A now? She ran over something and it popped the wheel.
Perhaps Craigslist or Ebay has someone selling take offs? Or look on the For Sale section on this forum. Good luck on replacing the wheel.
Must be a wife thing. Just remember a new tire/rim is cheaper than a divorce. My wifes van is all beat up (in my eyes). Constantly curbing tires (luckily rims ok). I am so happy she cant get my car out of the 3rd car garage (it would be wrecked before she got out of the garage)
Funny story from around 05. I had a 2000 Silverado, just put gas in it and washed it on a Sunday in February. At the time I had an 00 impala to drive back and forth to work and she had a ford escort. I get home and there is mud all over the truck. I was like WTF, ok wait and see her explanation. Also noticed it was on 3/4 of a tank of gas. She says nothing when I get in the house. So I ask, she explains she had a job interview, her car wouldnt shift into reverse (frozen). Then I asked about the mud. Being new to the area they sent her for a drug test, she got lost, hit a mud puddle and used 1/4 tank of gas. Funny to look back on.
My wife has two cars to chose from, a big one and a small one, not my truck. No one even dares to ask. My daughter ask once, I rented her one.
No way in hell my wife would believe that one.
Thankfully my grandparents and my dad didn't share the same mentality, although I'm a guy, when I first started learning to drive I learned in a 99 silverado (new at the time) and my dad's 93 3500 and then the brand new 01 HDs we had. Used to chirp the tires all the time too.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
