Finally got into the K02 club! I got a good deal on CL for these Mehtod NV's last Dec but never got around to getting them put on until now. Lost a little power to the extra rotating mass but it was less than I had feared. Rides better than my stock 20s did so worth the trade off!
17x8.5 285/70/17
Good choice! Those methods look awesome with that color!
  • 5 weeks later...
2017 GMC All Terrain BFG KO2 275/60R20 with Motofab 1.5" Level and Front Valance Removed
Day After Tires/Level Front
Day After Tires/Level Side
Day After Tires/Level Rear
  • 5 months later...
Any thoughts on going with a 285/60R18? Costco has that size for a great price over the 285/65R18. I'm wondering if the 1" height difference would be that noticeable. Right now I just have the stock Goodyear HT's.
17x8.5 285/70/17
That stance is killer. I’ve been looking at some method mesh wheels in 17x8.5. I’m leaning towards Ridge Grapplers for tires though. What level kit are you running?
Thanks, hasn’t changed at all from this pic still love it! Bilstein 5100s all 4, on highest setting in front(1.85), stock height rear.
Thanks for the reply. I like the thin profile of those mud flaps as well. What brand are those?
Weather tech, highly recommended! No drilling, took 20ish mins to install.
its what i'm getting when its time to replace.. .i'll do the 60/20... like OP.
On ‎12‎/‎13‎/‎2014 at 10:02 AM, JerryCanada said:
Set of KO2 installed about a month ago. Not as loud as the KO's I have on my work truck. This is 275-65-18 with a 2.5" front 1" rear RC kit.
Nice setup....real similar to mine.  Just curious...are those LT275 65 18 (Load Range E)?  Just wondering how you like your setup...ride, wear, etc.
2016 Silverado 1500
This thread has been very helpful to make a decision on what size to go with.  Here is my setup to help contribute.
Went with the 275/65R20 on a Rough Country 2.5" Level.  I ended up with slight rubbing on the rear of the felt fender liner.
No real comments yet on the setup as I have only put about 30 road miles on it so far.  MPG has definitely dropped off some and the ride is a little stiffer, can feel the bumps/potholes more.
Edited by Deprime
I'm currently running a 275/70r18 on GMC Sierra AT4 wheels. 2.5'' motofab upper strut leveling kit.
Love these tires! 275/60/20
Sent from my SM-G935V using Tapatalk
Nice set up! Did you put any level on up front? Any rubbing issues if not? I’d like to go to this set up but not sure what size tire I’ll be able to clear.
2" level. No rubbing issues at all. I believe I could of went a little bigger without issues.
Sent from my SM-G975U using Tapatalk
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
