This is the video I shot this afternoon. Hopefully you can see the flex of the bracket. Sorry for the poor quality of the video. First one I have done.
Wow that is awful! I thought I had "the flex" but mine doesn't flex that much. About 1/8-1/4" at most. You definitely need to bring that to the dealer's attention ASAP that is completely unacceptable. The fact that mine doesn't flex as much leads me to believe it may be an assembly issue possibly and it could be fixed somehow? I don't have adjustable pedals. Build date 9/2013. Rest of my vehicle specs under my avatar.
Edited by Silverado-Hareek
wow... 2015, (build 10-14) non adjustable and that is shocking.
I would never build peddles like that on anything even a go cart, let alone a $40k truck.
When it warms up I will try to put a metal block or something back there to stiff it.
Edited by frenchsquared
I checked mine and it had a good amount of flex before it engaged. Loosened the (2) 10 mil. nuts and popped a large metal washer behind the bracket. This took out about 95% of the flex. Prior to making this change I really had to mash the pedal to get the truck to get up and go. I was starting to get use to the mushie feel but like it much better with this make shift mod. I was really surprised how crappy the pedal setup is. Thanks for the info.
Here is a video of the adjustable pedals, you can see there is maybe a 1/4' movement before the pedal moves. My build date is early 2014 shortly after the 6.2L started shipping.
MAH00051
This is of the pedal movement. You can see the go the angle on the brake wrong so even though the screw is still moving the pedal stops, but the gas pedal is still moving closer to the floor. Silly they can't get that right.
MAH00049
I pried the plastic bracket away from the firewall at its lowest point and wedged a 1/4" thick piece of rubber. Works great, even with the small (1/8") amount of play mine had, the vagueness of throttle is mostly gone now. I highly recommened using something like rubber. If you use something metal, it has a good chance of rattling.
Edited by HondaHawkGT
Mine ain't broke, so I ain't "fixin'" it with a piece of stick and some goo.
Edited by patriot
I'm having problems viewing your video, can others view it??
Thanks
I hosted it on here, so something to do with the site. It was showing how the adjustable is not as bad. It flexes a lot, but it rests at the bottom of the flex making it not bad when driving. Then the bad pin placement of the brakes pivot point for the drive screw. I'll try and get it posted another way later.
Thanks, looking forward to another video that will show the non adjustable pedal bracket flex at a different angle.
Update on my paint stick. Have about 2k miles on it. Loving it. Truck drives so much better, especially in traffic. Sad part is I'm looking at buying a custom ordering a '15 Acadia Denali for my wife later this year... :) I ask for punishment in life I guess. I have just over 13k on the clock since August of this year (yes I drive a lot) and other than the gas pedal, frame rust and the 4cyl exhaust squeak I'm real happy with it. I've had it off-road on my job sites quite a bit. lots of hwy and city driving. Really like the truck. no vibes either. But I'm probly going to let 2 free oil change I have left go and do them myself.... last time they couldn't understand I wanted a tire rotation per the manual. And I paint marked the tires for them.
Edited by FL335i
  • 8 months later...
I must be missing something. I got under my dash and looked at the pedal assembly. There does appear to be some looseness side to side in the assembly and a lot of flex when you PULL on the gas pedal, but when pressing the gas pedal, there's very little flex in mine. I have not put a shim in to see if there's any real world difference but frankly, I just don't see how it would help, at least in my case.
I see two bolts, one lower and to the right, one higher and more left. I assume from the pictures that the shim is going under the bracket near the lower bolt, correct?
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
