Subscribed. Curious to know how to remove the air bag as well.
Found the plug. Staring directly forward after taking the "knee panel" off, it is taped to a loom of wires. Trying to attach a picture but having issues. It is attached to the loom from the black box with 7 plugs on it, I am assuming the BCM. If you go the third plug over that is green, and follow it up the loom, you can't miss it.
Thank you all for the help. It is working perfectly now!
Sent from my SM-N915P using Tapatalk
I envy you -- staring up from the green plug by BCM, and am not finding it whatsoever. Would have thought my truck would have had the plug -- there was a 7.5 amp fuse in the slot for heated steering wheel from the factory, would have assumed the loom was up there somewhere.
Anyone have a photo of what the connector looks like? Would appreciate the guidance...
Same here. Also how much does this whole change cost exactly? It would be a nice feature to have.
Searching eBay or parts sites are the best way to give you that quote.
Basically, whatever it'll cost you to get a heated wheel plus the clockspring, which is now part #23381964.
I think the wheel ran me about $200; the clockspring roughly $60 shipped. While the wheel can be second hand, make sure to buy the clockspring new.
Will stress that this proved to be a bit trickier to execute than I anticipated.
Once you have a heated steering wheel, you will wonder how you ever made it through life without one. Greatest feature ever.
I totally agree! It's like the best thing ever I cant live w/o haha
Is that click spring also for the 2014 model? Also curious when you said tricky what was tricky?
Look at what I have listed as my driven vehicle. Yes, this clockspring is for a 2014. You can try the older part numbers, but you'll see it redirects in EPC to 23381964.
As for what was tricky - everything. Airbag removal is a PITA. SRS wiring loom is also tucked WAY up into dashboard, which itself is not as accessible as older vehicles were, even after you remove a host of panels and the gauge cluster. No connector for the heated circuit present in my SLE, meaning I had to cut and splice, and run an ATR fuse tap (itself somewhat tricky to come by) from the DS fuse block.
Lots of work, and I'm not that impressed with the heat coming out of it, if I'm honest. Maybe I will be come winter...
Air bag removal
Yeah, well aware. Only studied this forum and the GM service instructions for weeks before tackling it.
It's tricky not for a dearth of information -- it's tricky because the process itself is a PITA. Working blind, essentially, and it's far less straightforward than the GMT-900s were.
Yeah, just wanted to share the procedure for the people in this thread that were asking how to do it. It is a real PITA the first time.
Anyone know if a Chevy and GMC wheel are interchangeable with an airbag from the opposite?
For example I have a GMC, can I buy a bare heated Chevy wheel and use my original airbag/horn pad with the GMC logo?
Finally had time to do this today. All swapped out and working flawlessly. Plug was exactly where Blaake said it was. Piece of cake! Thanks Blaaake. Here's a couple pics to show you guys.
4BC1D148-9BE9-4437-8637-72B07A0D8B19_zps
5F5D30D8-8558-42A0-8561-3CBDACA7240A_zps
AE8542E4-6386-4F34-A013-684B5E14FA9B_zps
6178C223-33CC-437F-A869-2F172766F4CD_zps
BB2F3AC0-3116-4CD0-8D54-2ADA9C3FE6A0_zps
89FD8DC1-B118-4BA0-929A-7483EF21A519_zps
356D63BD-07FF-40BC-B814-C97D0315DE70_zps
A4842E44-42EF-43AD-AE27-5EDBA69A8C9B_zps
I have my wheel and clock spring. Just so I understand... the clock spring will have a connector that plugs into a loom under the dash by the BCM?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
