Can remote strart b changed?
Hey u guru's can the remote start be reprogrammed for more run time? 10 minutes is for the birds in 10 degree weather, or do I have to go buy a aftermarket remote after dropping 40k on a new vehicle?
  • Replies 62
Can't be changed. You can initiate again during cycle to extend to a total of 20 minutes. But if more time is desired, then go aftermarket.
Why would you want it longer ? It's not good for the engine to just sit there and idle doe that long. If you want it warmer get in and drive it, it will heat up quicker!
Can't be changed. You can initiate again during cycle to extend to a total of 20 minutes. But if more time is desired, then go astermarket.
Just dumb
I work at 4am, and work outside, I'll let it run,
Been thinking of aftermarket anyway since the range on the remote blows
How is it not good for the engine to idle?
Just downloaded the OnStar app, droid anyone having success with this? How long will truck run? Tells me how much gas I got that's kinda cool but all this makes me nervous lol I'm old school,
Remote start will run for 10min., when you get to 9min. hit the lock button and remote start again and it will run for another 10min., if you do this before waiting at least 9min. then it will start the second 10min. at that time.
20min. is plenty of time for even the coldest weather.
I agree when it is bitter cold out 10min. is not enough.
I agree usually 20 is good, this morning it was iced up pretty bad, gotta see where I have things set, because after a 25 min ride nothing was defrosted except mirrors and rear window, love the automatic rear defrost, sometimes after work on bitter cold days with wind I've been known to let it run for 1/2 hour or more, don't think it hurts anything except gas mileage and oil life, but then again maybe there's something I don't know
Was -29 this morning. First cold snap this winter so far, so not too many complaints. Started first time and ran for about 7-8 minutes before i remembered to redo it and let it run for a total of 18 or so before i got in it. It was still cold when I started driving away from my house. No heat output until a few miles down the road. Yes 20 minutes is necessary.
You must live around Fairbanks. I lived there for about 8 years. Crazy how -10F will feel warm after a stretch of -40F. Coldest I ever saw was -67F, 20min will not even defrost the window.
Yup we offer it as part of our custom bcm programming. My truck for example runs for 12 minutes per cycle.
Sent from my iPad using Tapatalk HD
How far out can you take the cycle? Is there a limit?
    • Correct.  2019-2020 are serviced by a different p/n.  19420611.   The recall engines 2021-2024 are serviced with 12740076.     What the difference is between the two, I'm not sure, but 2019-2020 only show 19420611 as the replacement engine p/n.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
