The 6112 is a shock and spring package not sure about the pro comp. The 6112 spring will be softer than the oem spring
The Procomp black series is a 2.75" strut with springs, that's why I'm asking how the 6112 compares as a direct competitor of the Black Series.
The link I provide shows all of the detail, I'm not sure of the price point on the 6112 but these are 499ea and maybe an alternative to the 6112
Not sure about the price Iam thinking about 750 for the pair will available.
The other must be better these don't exist yet.
Sent from my SM-N920V using Tapatalk
Happy New Year everyone. I will have some R&D photos of the GM being tested in the coming weeks.
Do you know if the 6112's are the same length as the stock shocks? I've run 5100's on my past two vehicles, and the upper settings have always lead to a fairly stiff ride. I know with the new springs this may not be the case, but I was looking to run a 1" lower mount spacer and then set the 6112's to the 1" setting for 2" of lift and a less-harsh ride. If the 6112's are longer than stock though, this may not be possible.
I wonder how Bilstein is addressing the difference between the steel arm and aluminum arm trucks? Fox sells two completely different units, the ones for the aluminum trucks only giving about 1/2" of lift (found out the hard way). Other companies sell one model for both trucks. I ditched my Fox units because how little lift they gave me and am considering the 5100's but the 6112 has had my attention since last year, just the never ending wait to see if they will be built and if they'll work on my truck.
I'm thinking of ordering the Cognito UCA's to go with what ever I do. I have a feeling the stock UCA is a big issue with ride quality and definitely suspension travel when we lift these trucks with leveling kits or the like.
Only difference between the aluminum and steel suspension is the ball joint taper sizes. I don't see why companies would make different shocks for the different styles. UCA's are the only thing that would need to be different.
Edit - I just took a look on the fox website and you're correct they make the 2.0 specifically for aluminum suspension, I wonder if it's just valved differently to compensate for the reduced unsprung weight.
Edited by projectsummit
That is exactly what Cognito told me. I was so disappointed with my Fox 2.0 experience I sold them with 5 miles on the for half of what I'd paid. The solution from Fox was to crank up the pre load. After they shipped them back I sold them instead of putting them back on. They told me if I had bought the version for steel arm my truck would've had almost 3" of lift. Better than 1/2" IMHO.
Nope, different overall length and shorter stroke/travel for their aluminum version. Different coil spring too.
King and pretty sure Icon (plus Bilstein 5100) only spec one model for both trucks.
Edited by TeeDub21
Very odd, but you never did try adjusting them? I'm about to buy a full 2.0 set for my 2015 f150.
The springs are so stiff the average person with a rented spring compressor would have a tough time. Plus the coils are so small and close together the one I rented wouldn't work. Took them to a shop with a wall mount compressor and they couldn't do it either because their compressor wouldn't hold the smaller diameter fox coils. Fox agreed to pay round trip shipping so they could adjust them. They cranked up the pre load (which would probably make them ride worse) and said that I "should get 1.5 inch of lift with them". Had a bad taste after spending over $1,000 and not feeling I got what I'd paid for, so I sold them.
Put my 2" level kit back in and went back to my shitty Rancho ride until I can decide which way I'm going to go.
that sucks, I hate situations like that.
The problem with the 2.0's for my new truck is that they were originally made for the 2014's so now that they have an aluminum body they give about 2.25" of lift. I'm having fox adjust them for me to 1.75" before sending them. I'm hoping that lowering it will make the ride more plush.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
