Can you guys give any height gained numbers per setting? So with 4 settings we know the bottom one gives no lift.
What does the 2nd, 3rd, and 4th setting yield?
Not talking about what Bilstein claims but what you guys with experience got. Like after the truck had time to settle what you actually got lift wise per settling.
Edited by NEMESIS-A/T
Just a hair over 2" on top setting for me.
The price you have quoted for a set of four shocks is close to the price quoted for one front 5100 from my dealership!! Has anyone reading tried ordering from British Columbia? If so, what was the final cost?
I hear you, I was in Rossland last month and the pricing on things is very random. I can ship to BC :)
PM sent. I was visiting the Houston area last week and called a local 4Wheel store to inquire about Bilstein levelling shocks. The person I spoke to said they recommend using spacers with Bilsteins set at the bottom (stock) setting. This really struck me as "overkill" but I assumed he knew what he was talking about. All I want at this time is a 1.5" or 1.85" front lift with no negative impact on my suspension. Ideally, I would like this to be an improvement in function as well as looks!
Apologies if this is a repeat, I cannot possibly go back to read 33 pages.
My local shop is suggesting the Bilstein's are not valved properly for the Max Tow/NHT and to wait until Billy or others come out with shocks specified for the NHT.
MRT or others, is that consistent with your understanding? Please and thanks.
Sounds like they are just trying to up sell you in my opinion. Any reasons given?
I believe on Bilsteins site it says not for Max Tow.
Edited by jrob56
No, it was simply a statement that this is the way that they do a level. He sounded quite authoritative and confident. I assume there must be a reason other than a cash grab. He readily gave a price to level with spacers and had the Bilsteins in stock if I wanted them as well.
There's no reason they wouldn't work, other than dampening. I've used 5100's on other "max tow" equipped trucks (Titan) and it was a vast improvement over stock.
Those shocks will bolt on to the NHT truck, they might not have enough dampening to control the rear spring on the NHT tho.
Per this thread, a few users have bilsteins on the NHT equipped trucks.
http://www.gm-trucks.com/forums/topic/162049-nht-ride-quality/
Another good NHT info thread - http://www.gm-trucks.com/forums/topic/172318-2015-silverado-nht-suspension-upgrade-help/
Edited by Mack207
^Thanks Mack, recall seeing something to that effect. I have the airbags coming, but may go ahead and just slap in the non-height adjustable Billys as well, gotta be an improvement over the stocker Ranchos.
Why not? You have something better to do? :lol:
This is correct. I've been looking for replacement shocks as well
Edited by xelli
Has anybody ever experienced a very stiff ride on a freeway? I have bilsteins on the 2nd from top setting with 275/70/18 ko2s running 45 psi. Last week while driving through L.A., the entire cab began bouncing/shaking. Felt as if I had a flat. That was the worst case. Normally on the freeway it just feels like a very stiff front running over a ton of small speed bumps. Best I can describe it.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
