No the rears are a set height...not adjustable like the fronts
Correct they are not adjustable like the front but they are designed to handle raising the rear with a block at least 1" I think I read in this thread they may also work up to a 2" raise but I would double check that.
I would say yes...I can't tell u that 100% cause when I did mine I also added air bags so it seemed to lift the rear a little....but I am pretty sure it will sit the same with just the shocks
Can anyone comment on this?
Is the ride quality on Bilsteins significantly better than the Beltech's? I am looking to soften the ride on mine, particularly the rear. I'm getting annoyed by the harshness on rippled roads, manhole covers etc. THANKS
I had 5100's put on the front this AM. Rode great on the way home very happy. Just put the rears on myself took it for a ride slightly stiffer but still great and I would never go back to Stock.
Never had Beltech's, had Bilsteins on my last truck and was very happy.
The Bilsteins are much better than my Z60 set up on my 1400 mile Sierra.
Not sure you would feel that way but I a do.
So I have been reading this thread and I can't seem to find a definite answer. Can Bilsteins be ran on RC 2.5'' level front and rear? If so, what model of bilsten and what level are they set at? I have an RC 2.5 level and it rides a little rough so I am hoping to smooth it out some. I need ever inch I can get as I am running 33x12.5 on -24 wheels.
Just purchased my Full Set of Bilstein 5100's from MRT Motor Sports.Hoping it levels the truck for the most part. Now the wait begins......
Thank you for the business!! We will get these shipped out today to you, hopefully for a Wednesday or Thursday delivery.
4600s (Yellow) can be used no problem. 5100s will need to be used on the lowest setting only.
I had them sent to my friends house so that my wife wouldn't see what I got. I told her I was getting a $50 leveling kit lol. Going to install before she sees what I got. Wish y'all had Koozies to keep my beverages cold!! Or did I not see them on the site?
Ive got some gear leftover from the offroad expo left over, I will send it your way. Also just shot you tracking on the shocks!
Thanks!
Thanks!
Awesome!!! Thanks!!!!!
Very common for the 2.5" leveling kits to have a 1.5" taller than stock rear block. Stock rear is either 1.5" or 2" if a z71, you said it measures at 3" overall which sounds like the 1.5" larger rear blocks. The 5100 are rated 1" over stock, but can really go to 2" if you are beating on them offroad.
Good info , 5100's ordered!
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 755 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
