Super fast shipping, great prices. Thank you ! Highly recommend MRT.
They came in already...looking forward to installing them when I have some free time. Going to PM you on some wheel prices here in a little bit.
Thank you sir! If weve got an item in stock, we try to get it to you within 72 hours! We are greatful for your business!
If anyone else is looking, our pricing in unmatched and our inventory levels are pretty good right now for fast turnaround.
07+ GM / Chevy 1500 2wd / 4wd Bilstein 5100 Complete Set - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2423830433238319/i-2304103.aspx
Have they came out with 5100's for the new Colorados?
Yes! Weve got the kit here - 2015+ GMC Canyon / Chevy Colorado Bilstein 5100 Complete Set - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2425315424265874/i-2501887.aspx
Are there better coil springs, maybe an eibach spring to go along with these to increase ride quality?
Same thing I asked. After some research I found out that the factory coils are 550 lbs./in. spring rate. So it's a matter of coil length and spring rate. I should just call Eibach and ask.
Edit: Many of the popular coilovers use (up to 3 inches of lift) an Eibach Coil-Over Spring, 3.0 in. Inside Diameter, 14 in. Length, 700 lbs./in.Spring Rate. They cost around $100 each.
I happen to have a spare set of factory coils, so I'm going to measure them this morning. So our factory springs measure around 12 in. length wise. That's why RHA struts support up to a 2 inch lift without a problem. I'm going to add a video that helps explain it all.
Edited by Severado
The valving in the shocks is designed to work with the factory coil spring, upping the spring rate may cause a worse ride then factory. If you havent tried the 5100 shocks on their own with the factory springs first, you might be getting ahead of yourself a little. Almost all aftermarket springs will be a heavier spring rate, which may not be what you are looking for. We normally bump the spring rate by 50lbs for every 150lbs of added weight over the front. We can supply "universal" coil springs that will fit these shocks no problem, but we would need to know the requested spring rate and length.
The third ring on the 5100s was just a smidge lower than the 4600s + 1.5 level. That level kit left me perfectly level looking. I did not like it. I still wanted a slight rake since I tow and the third ring left it just like I wanted. I cant imagine doing a 2" without adding the rear spacer. It would look nose high.
I never ran the 4600s without level. I did both (and new tires) all at the same time. THat made it really hard to diagnose the issue. I think it was the level kit though if I had to put money on it.
Edited by Texas_GMC_Z71
Excellent review. We suspect is was the spacer, as the leveling spacers limit the already limited travel these trucks have from the factory. The 5100 is a superior shock to the 4600 in ride quality as well.
So far I am happy with my ride at setting 3 on the 5100s. I do like a more firm ride though, stock was too soft and non compliant.
I've got the 5100's front and rear, front's set to 3 as well. The front shocks perform well- very well behaved. The 5100 rear shocks are a little jarring though. Much more so than the Bilstein 5160 rear shocks I had on a 2016 Tacoma. I was kind of surprised.
Thank you for the continued orders!!
We are stocked up on 5100s, get yours here - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2423830433238319/i-2304103.aspx
Do you have the NHT Heavy Tow package?
Well after having 5100's on for a year like them even better. They soften up a bit after carrying medium:heavy payloads and some towing.
Yellow/Blue = 4600
Silver/Black = 5100
Both a big upgrade over the stock shocks. Go with the 4600 if you want to keep stock height or are needing maximum control for towing or want to run a leveling spacer. Go with the 5100 if you want to level the truck without a spacer or if you like to go offroad.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,226 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
