They're working great, for a direct replacement using stock springs they are light years better than Ranchos. The 6112 should be awesome. The Toyota guys love them and say they're comparable to KINGS/ICONS
Sent from my SM-G950U1 using Tapatalk
Do we have any idea when they will release those?
They expected to date has come and gone. Who knows ?
Quick question..
2014 sierra crew cab
I got 275/60/20 Discoverer AT/3 and doing the Billstein level on top notch.
Can i get the tires mounted first before the shock install? Just wondering if it will rub hard untill i can get the shocks installed the next day or so.
According to the "Technical CSR" I've been emailing about these for the last few months, the current status is "They are due in anytime now, waiting on spring coating."
They always have one reason or another, but hopefully that is the truth. They have been due since last year. I will believe them when they arrive to our loading dock!!!
On 10/23/2017 at 5:24 AM, Ozer said:
Quick question..
U-Turns will be hard. But if its just for a day I think you will survive.
I just read a thread on the Bilsein bump that occurs after installation of the shocks. It seems the top plate does not get tightened down all the way unless you use a washer or spacer under the shock top nut. I have been having some noise in the front end since the swap over washboard sections in the road. I checked this afternoon when I got home from work and found my top plate loose enough to move. So I did some searching and found the thread mentioned above. The bad part about trying to correct tbis is you gotta almost stand on your head to correct it. Maybe not tomorrow night but by the weekend I will have done something about it anyway. I'll link the thread here tomorrow.
My Bilsteins set on the max lift were installed earlier this year so (living in the Midwest) this is first they've seen cooler temps.
On the expressway today the truck was really riding funny. Kinda like very small whoops so it felt like it was bouncing up and down really fast. ( I was going between 70 and 80 mph)Not like with out shocks.. It was very stiff feeling. I wrote it off as just being that section of highway combined with the trucks wheelbase.
Later I was on a totally different expressway and felt the same.
Anyone experience this? Would a spacer lift work better for ride quality with the shocks set at stock height?
Also Eddie 70, mine makes a light knocking/ rattle noise when going slow over terrain that makes the truck flex side to side. Nothing big.. Just driving across the yard will do it and I can't find anything lose.
I went out to the garage tonight when I got home and checked everything really closely. The top plate was VERY loose. The best way I found to tighten the bolt was through the fender well. Hold the wheel well liner back, rotate the shock shaft so you can hold it with a small crescent wrench. Tighten the 16MM nut on the top of the shock until it is tight against the top plate and no more movement is noticed.
Read this thread for pics.
I have driven approximately 175 miles since I did this the other day. This was the fix for mine. It may loosen up, but I can't imagine it would using the supplied nuts that came with the shocks. They are just a tad undersized and you have to use a wrench to run them down. However, if it does loosen, I will double nut it.
SO much better with them tightened down. The truck is almost quiet again and it has 92k miles. I am excited again!
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
