12 minutes ago, pronstar said:
It’s absolutely possible to get a smooth ride. It’s just not cheap.
If you’re ever in DFW and would like to ride in a smooth pickup, I’d be happy to take you for a spin.
8 minutes ago, Snowcamo said:
Actually I'll take you up on that offer... I live in North ft Worth. I'll be out and about in Dallas then Lewisville today.
Yet another match made on GM-Trucks.com. How romantic. JK :D
  • Haha 1
I live in Duncanville, work in Carrollton [emoji106]
Hey I just moved from Carrollton 4 months ago lol. Real estate has gotten a bit pricey over there. Good time to sell... Let me know. I'm usually available afternoons on weekends if I'm not doing HVAC.
Sent from my LG-LS993 using Tapatalk
Yet another match made on GM-Trucks.com. How romantic. JK [emoji3]
2 guys, 1 truck [emoji50]
  • Haha 2
Check your pm’s [emoji106]
My personal experience on ride quality, bought my new 18 6.2,CC, Standard bed, was shocked at how smooth it drove, being a z71, 4x4 it really drove very much like a Cadillac, drove over bumps like I was riding on air suspension.
Leveled with a 2.25” up front and added 1” on the rear and that’s when I immediately noticed a rougher ride, only adding to the rougher ride I added the E KO2’s and that was it, rode very much like something just wasn’t right, you felt every crack and crevice almost like my 16 DMax did. Btw, I’ve got Bilstein 5100’s all the way around too
A buddy of mine has a lifted truck and actually rode more on the plush side. Apparently, the more you spend (get what you pay for) the better the ride quality. He’s running custom tuned Fox shocks with adjustable resi’s with custom coils as well as the rear but most of all he’s saying your track width has a lot to do with it too. I know for sure my level is messing with down front travel etc and After being introduced to the CST lift kit from a few guys on the forum, I’m proud to say I’m having the 4.5” CST installed within the next few days, so close to getting the 6” but then no way to get it into my garage as well as parking garages which I often visit. All in all Pronstar is one of the many that are correct in this forum, achieving a much “smoother” ride is work in progress but doable
Sent from above
Sent from above
Sounds like you're using spacers and 5100's at stock height?
By track width, does he mean lower offset wheels would ride better, due to changing the leverage on the suspension?
Good information to know TX. Seems like there would be a market for a plush riding small lift.  Makes me wonder, I know the 19 Silverado is all new so I assume the struts are not compatible...?  GM is offering a 2" lift strut on those.
Correct, a pc on top and one on the bottom of the front strut Bilsteins also added 1” on top of the rear. A knuckle lift is what pops your front wheels out approximately 1.75” needing a rear wheel spacer afterwards in order to balance out the look. I like the +1 offset I have now with all wheels flush with fender and tires popping out on the sides about 1.5”’s. I DO NOT like my track width to come out at all, not my thing, and especially DO NOT and WILL NOT EVER run wheel spacers.
As far as the 19’s, GM has changed out the suspension on the 19’s. Incorporated a 2” lift standard either on (I believe) Trail Boss as well as an add on option for ordering. I’m not very familiar with the 19’s, they sorta remind me of my 2001 truck I had, sharing same front end similarities.
Sent from above
I can't even begin to describe how frustrated and embarrass I am at this moment.
When I originally had my 5100's set-up installed 3 years ago, I bought the parts directly from Summit about a week after they were made available, however after having them installed it simply never even occurred to me to actually check the part numbers since I Supplied the installer with the parts. ( Top rated 4 x 4 shop in Phoenix Arizona).
Last night while installing my powerstop z36 brake kit I started really staring at the part stickers on my shocks and after a bit of research realized that the parts that I paid for we're not the parts that were installed and I have been driving around for 3 years with the wrong parts.
Certainly a brave keyboard Warrior will likely flame me stating that I should have figured this out sooner however I had them on their highest setting for quite a while and figured that the miserable ride was due to me having the front adjustable shocks at their maximum setting, thus I have simply tolerated it until recently when I had them moved to the next lower snap ring setting and the harsh ride continues.
I have studied the part numbers for hours on end on a plethora of websites and there is really no good detail to help correlate what the differences are beyond the fact that the rear shocks are a bit shorter by about an inch.
I guess I will have to call Billstein during their normal business hours, to figure out how big of a problem this really is or if the differences are actually inconsequential.
Current Front: 24-186940 ( pre 05 - 2013 trucks)
Current Rear: 24-186742 ( For GM 900 )
Correct parts for our 2014:
Proper Front: 24-238304 (Adjustable)
Proper Rear: 33-238319
Could one of my Texas brothers please come over and just shoot me in the head... LOL.
Oh My God! Summit Racing is exactly where I bought mine from and has been rough riding since they were installed on my leveled truck. Looks as if Summit Racing sells knockoffs! I’m having a lift done tomorrow anyway.
Sent from above
No no this is not an issue with Summit they sold me the correct parts I am simply saying the installer which was a retail location in Phoenix, apparently installed the wrong parts or someone else is parts but not what I had brought with my vehicle
Ok, looks like they swapped you out.
Sent from above
Just as a quick update I had an opportunity to talk to Bilstein today and indeed the valving is significantly different between the GM 900 parts and the correct parts 4 the K2 trucks.
Below is a brief summary of the differences
Front: 24-186940 vs. 24-238304
1. Rebound: -1000n (-225lbf)
2. Damping: -100n (-25lbf)
3. Shock body is .5 shorter
4. Snap ring locations are higher on the body
Rear: 24-186742 vs. 33-238319
1. Rebound: -200n (44.9lbf)
2. Damping: -200n (-44.9lbf)
3. Shock is .75 shorter, thus overextended
You buying the correct shocks and struts to swap them out?  Glad to here there is a reason why your ride was so bad.
    xdieselmechanic
    xdieselmechanic
  • Who's Online   4 Members, 0 Anonymous, 622 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
