How much damage to her car? I got rear ended years ago when a clown tried to beat a yellow light & I was stopped beyond that behind a line of cars. Tweaked my rear bumper but major damage to his Monte Carlo. The rad support was laid back about 45* & the hood was buckled up like an "A".
It was a Jeep Liberty, so with its taller front it it spread the force of the hit out some, but I am sure totaled.
7B98CFBD-D309-4F4E-8C95-7B79999D1363_zps
Made it to the dealers lot! Should get her the end of the coming week. Long wait for the build- 7 weeks it's almost home
When I get her home and the weather is good, I'll get some more overall pics up
Good luck we had crappy weather after I picked mine up & then winter arrived. Other than going to the next town (half an hour away) & washing it, I won't have any decent pics until next spring :-(
My 2015 2500HD 6.0
Current upgrades:
Ranch Hand
Marimito HID Low
Marimito LED high
DQS mirror upgrade and reverse cargo tap
8" nav screen with HMI update
BAK bed cover
BAK Box
Small Onboard air compressor
Mounted Power inverter
Upgraded interior trims etc
Next comes the Back Rack headache rack and a Go rhino rear bumper
Pallet of rock 3,000 lbs, all fits with the accessories, truck didn't care about the weight...
Forgot to mention the 20 inch Denali wheel upgrade and the Black Bear tune, endless stuff done to this truck already...
Edited by Aleksrussian
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
