Bds 6 in or 4 in and a few questions
Well the time has come and I have decided to lift my truck 2014 GMC Sierra Sle z71. I am sold on the bds kits but I do not know whether to get the 6in or the 4 in kit. The tires I would like to get are 35 in toyo at2 with 20in fuel hostages. But I am also stuck on deciding whether to get 35s or 33s I really do not want to have to do any trimming. I am going to get the fox shocks in the rear with the leaf spring option as well. So the main questions I have are
1.does the lift kit void the warranty?
2.should I go with the 6in or 4in lift kit ?
3.Should I go with 33s or 35s ?
4.Will there be a major change in the accuracy of the speedometer?
5.if there is can you please tell me how to fix that?
6. Can anyone who is running these kits show me pictures?
7. How is the ride after the lift?
8.how much is the change in mph with the 6 and 4 in kits
If in the end if I do go with the 6in lift I am going to get 35s regardless I personally do not like the look of having all that lift and small tires. I was debating on 33s if I get the 4 in lift but it can also fit 35s .Im sorry for all the questions but this is the first time I am ever lifting a truck and I would like to do it right . I am open to all opinions and all replies are greatly appreciated
Go with the 6 inch coilover kit. It will not void warranty (kits approved by GM plus have their own warranty). 35's FTW. Get the speedo recalibrated either through dealer or handheld tuner. Ride will be at or better than stock.
I will add that if going with 35's I would regear when you have the coin. 4.10's at the least, 4.56's preferrably. That's just my opinion though
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
