CB install, anyone have it yet?
It's a midland 75-822 modified. Little bigger than just a mic but definitely tolerable. It's 3 foot firestick II tuneable antenna.
  • Replies 124
Skippy4- how about that wind report update?
i've used many of those fiberglass antennas before and never heard any wind noise except when i had them mounted on the mirrors on a 66 chevy pickup.
No Wind whatsoever. very glad i put the antenna on the spring. pulled nose into garage to work on front end and forgot about the antenna. luckily spring was there.
quick disconnect for antenna ????
I'd be worried of it springing back and whacking the cab and chipping the paint
spring barely moves for the most part. unless you pull into a garage and literally pull on the antenna. an inch sway even at 90.
open ended wrench for quick disconnect.
YES Sir - that will also work. BUT most people don't carry tools anymore ? I still have a basic set in the truck .
Thieves will (lol)...
yes I have quick disconnect on my antenna , mainly when I go to a parking ramp . NO street parking. I used them since the late sixties , no problem with them being taken.
Installed.
Glad your stake mount worked with having a tonneau cover on the bed. I was toying with that idea for a while, since it worked for you, I'm ordering one and going to put my antenna on my truck that way.
good clean installed . is that a 4 ft. antenna ? how about a quick disconnect - garage / parking ramps ?
I thought about a QD for my antenna, but I've had things taken out of my fenced in backyard, both big and small. With where I live, I batten everything down. When my stake-mount comes in for my antenna, I'll be buying a pair of open-ended wrenches for when I have to park it in a parking garage, IE Universal Studios, Disneyland, etc. Even with the spring, it still tore up my last/current firestik.
First time I took my last truck to Universal, I was smacking every single concrete rafter, so I stopped, pulled out of the way, only had a 1/2"x9/16" combo-open-end wrench, grabbed a quarter out of my pocket and used the 1/2" end to remove my antenna from my mount. After we left the park, we stopped at Denny's along the way, and I threw my antenna back up. 40 miles was too long to be without my CB.
Drove through plenty of drive-thru places, whacked my antenna on their "overhead clearance" signs/crossbars, and with the spring, never whacked the cab on my previous truck. The spring is pretty rigid for a spring. Going down the highway, my antenna would wag left/right at about 1" aft. I've seen a few older trucks rigged up for prerunner/long-travel/off-roaders with a steel 102" whip in the forward stake hole, and even after "trimming their neighbor's trees, that whip never hit their cabs.
Ok. Finally months later I got some pics posted. I will take pics of the antenna today. I'm running a 3' lightweight firestik. SWR is at 2.2 according to the radio. Yes it's high. I believe I need to work on grounding the antenna better or adding a 10ga ground wire to the base in the fender. Few notes here... the Coax is running through the firewall through a spare boot would be cable. So I cut the tip off it and ran the coax through. Once everything was in place I used clear windshield silicone to seal it up well. Coax then run under the center console and comes up under the cup holder area. I drilled a hole in the console, under the cup holder area, uder the rubber pad down there for the coax to enter in a corner. Then terminated the end of the coax. When my CB is not in use, I store the coax lead under the cup holder area. you do not see anything. When in use, the coax runs through a gap between the cup holder and the console in the corner. For mounting the radio I went on Ebay and found a vendor that sells PVC/Plastic sheets. I had him custom cut. Cost me like $12 shipped to the door. It's 1/4" thick PVC sheet. 9-78" long, 3.75" Tall. I then mounted the radio's normal mounting bracket to it using some counter-sunk SST screws from HD. The PVC sheet fits into the vertical slot channels in the console. This system truly works beautifully. It takes 15 seconds to setup and take down.
I am adapting your CB location to fit my mine, only difference is mine will be paired with my scanner in the aft/deep part of the box. My cup-holder are pre-positioned in the second position for it. My iPhone/iPad sit forward of the cup-holder, so I can see them and whatever is going on with them.
I am adapting your CB location to fit my mine, only difference is mine will be paired with my scanner in the aft/deep part of the box. My cup-holder are pre-positioned in the second position for it. My iPhone/iPad sit forward of the cup-holder, so I can see them and whatever is going on with them.photo's
photo's of install . please
definitely pics please.
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
