On 5/14/2018 at 12:41 AM, z71truck82 said:
Just confirming the black HD has 35x12.5x18 tires with no lift at all? That’s crazy.
Correct, I'm running Bfgoodrich 35x12.5x18 on stock wheels w/ no lift or modification of any kind to the suspension.
I was originally concerned about clearance, but any shop I spoke with or post I read did not actually mount one and check clearance prior to lifting.
Will always consider a lift / spacers or new wheels but for now the rubbing is not an issue.
Driver side rubbing chassis at full lock
passenger side rubbing at full lock
Sway bar has no contact
Edited by OpsWest
Okay cool thanks. I ended up ordering 17x9 +18 offset wheels, and 295/70R17 tires (33.3”x11.77”). Hope it will all fit. Might give the torsion bar bolts like 2 full turns to get front end up about .5”. I tow a 7500k TT so want to keep the rake.
Edited by z71truck82
On 5/14/2018 at 2:24 AM, z71truck82 said:
Going to get after market 17s with at least an 18mm offset. Can you attach a link to your pictures please.
I"m guessing that was directed towards me. I don't have any pictures in my gallery, but here's a link to the build thread where I posted pictures of my truck along the way:
On 5/19/2018 at 2:10 PM, z71truck82 said:
Last question...when you turned the keys did you jack up one side at a time or both? I think I will turn 4 times and see if the tires fit. Thanks
I did one side at a time, but there's no reason you couldn't do both, as long as you can find a good placement for the jack.
Just sharing my experience with my 2018 Silverado HD. With 20x9 wheels +18 offset and Nitto Exo Grappler 275/60/20 (measure 33.25x11), they fit with no rubbing on completely stock height. The tires come VERY close to rubbing on the thick gatorback mudflaps. Without the mudflaps (or maybe with a set of kickbacks), you may fit one size bigger tire with this offset wheel.
On ‎6‎/‎12‎/‎2018 at 10:03 PM, z71truck82 said:
Thanks GForce! Would you mind posting a picture, including the ones where we can see how much the tires stick out of the wheel well. Thanks!!
here's a couple pics. I'd say the tires stick out roughly 3/4" - 1" passed the fender well.
Anybody know if I can fit Nitto Terra Grappler G2 295 60 R20's on a stock 2015 2500 High Country without doing anything to the torsion bars?
And if it just needs a little adjusting with the torsion bars will it make it that much rougher of a ride?
Thanks!
Thanks!
If you're keeping the stock rims, they'll probably fit without any lift. However, if they don't, then it won't take much torsion bar cranking to make them clear. And, as long as you keep the front lift at 2" or less (and add shock extensions) the ride will be just fine.
Thanks!
If they don’t rub your going to be very close. I just put on the G2’s in 275/65/20 with aftermarket wheels at +15mm offset. I was very close to the front fender and would just rub the liner at the back with full turn. Your a little wider but with the stock wheels. Like the other post said if they do rub you probably won’t need much more to clear.
good to see this. now im very much considering running a 35x11.5/20 with my stock 20s. (from research, they appear to be the same width and offest as your 18s. )
  • 4 months later...
I have a 2015 GMC 2500HD All Terrain with stock 18 inch wheels and 265/70r18 tires. What is that largest tires I can fit on these factory wheels without rubbing. I was thinking of the BFGoodrich All Terrain KO2 285/65r18. Thanks for you input
285 75r18 on 18x9 with a +12 offset, the offset had me switching the stock keys for aftermarket torsion bar keys, so I could get the tire off the front mud flap at full lock.
    Tbhats2130
    Tbhats2130
  • Who's Online   3 Members, 0 Anonymous, 2,259 Guests (See full list)
