What do you wish your truck had?
Is it free? or do I have to pay for it?
It is free if your truck is still under warranty. If it is out of warranty the dealer will probably charge you for the Tech's time to do it.
Guy came into our shop yesterday with a 2017 Chevy High Country
I've never seen optional, production, GM power folding running boards...... That also has a hidden switch (in the end) to also power fold the running boards rear-ward, to the bed!!
Pretty cool. This helps your reach the front area of the bed!!
Anyways, I've never seen these before. :thumbs:
They came out with the 2016 redesign. They are an available option on High Country and Denali trims.
I like that they pivot toward the rear but they don't drop "down-and-out" like the Amps so they don't really help with the step height getting into and out of the truck.
  • Replies 210
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
