So, I buy the cluster from the dealer then send it to someone to program my mileage and my vin to it, then install it?
Remember that your truck won’t have all the features/options that the cluster supports. So it gets custom programmed to work with your truck, your VIN, your features.
Yeah, plan is to buy it then send it to the company mentioned on the last page to get it setup to work for my truck.
So this will work in my 2014 Silverado?
Yes - So long as you get a cluster from a 2014. On page 29, all the part #s for each year are posted.
Page your turning into my upgrade guy. I found a center console in Iowa 150. Still gonna need your wiring harness
Yes and make sure you do it in that order.  If you install a cluster into your truck before it is programmed for you VIN you will brick it and it will not work at all.
And as pgamboa said you won't get all the Denali options.  WAMS can get you most of them but there will still be some Denali screens that won't show up on a non-Denali truck.
Anything that’s available and optioned on your vehicle will show up, that’s the way it works :)
Anything special required? Do we just need the new wheel with the controls and the DIC and then programming? Interested in this too!
Hello I have a 2014 GMC Sierra 1500 slt all terrain I have had no luck finding a Denali cluster any help
On 6/13/2018 at 10:10 AM, bsprtsgrp said:
Ordered my 2015.5 #84254161 Denali Cluster yesterday from my GMC Dealer, should be here end of week.....
Received my new 2015.5 Denali Cluster from my GMC dealer last Thursday and shipped same day to Chris White in MI via UPS which he will receive today...
Before picture...
Edited by bsprtsgrp
Installed...thanks Chris White!
Edited by bsprtsgrp
4 hours ago, GTPprix said:
You’re welcome!!! :)
You are wams? I just emailed you yesterday. Getting a cluster was a pain but spemco sold me one.
45 minutes ago, David Kimbrell said:
I have a 2014 gmc sierra sle package, is there anyway i can upgrade my cluster to a Denali cluster? something like that.
Contact wams. Give them your vin. they will tell you what partnumber will work
Mine is on the way to them as we speak
I am installing the HUD in a 2017 Silverado High Country. Can anyone tell me if the HUD systems are year specific? I know the instrument cluster is.
    • If it has a stick I can have fun with it. When my wife first got her Acura years ago I used to tease her about it. I was only interested in muscle cars. They’re gone now. So once a month I drive the Acura. Every once in a while I’ll take it to Redline. But just normal driving on some twisty back roads usually does the trick.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
