The manual seat in my 2010 WT was more comfortable than the power seat in my 2015 LT. I wouldn't say it's uncomfortable... just not as good.
I don't know why they always monkey around with seats. I wonder if they are trying to see how cheap they can make them and still get away with it. I guess it is pretty hard to make a one size fits all seat though.
I also noticed that they did away with the fore/aft adjustment on the headrest on the 2016's. This is a very nice feature that I found totally by accident one day. I bet most owners don't even know the headrest moves that way. It is on a ratcheting mechanism that you pull forward to release. It's nice to be able to move the headrest so it doesn't rest on the back of your head.
Edited by THD
having owned both a 2014 and a 2016, there are differences between the years. the 2016 are softer and more supportive than the 2014. as far as overall comfort, they are slightly better, and seem to be wearing better also. these are (were) leather heated/cooled in both trucks.
Seats in my '07 SLE II were cloth and quite a bit more comfy than the seats in my '16 chebby Z71. But maybe after 9 years of driving my SLE the seats and my azz kind'a bonded, formed a good relationship LOL.
My 15 with the 10 way power is the first vehicle I can drive for 8 hours without getting lower back pain. And I'm 6' 165 so not a exactly a big guy lol
I don't like the way headrest is angled so far forward.
The head restraints adjust forward and rearward.
To adjust the head restraint forward, grasp the head restraint and pull forward to the desired locking position.
To adjust the head restraint rearward, grasp the head restraint and pull forward fully until the mechanism releases and allows the head restraint to return to the full rear position.
EDIT: this from the 16 denali OM. The non-denali om does not have these instructions.
Edited by redwngr
Doesn't say anything in the owners manual about this.
That was cut and paste from the OM.
EDIT: it was from the deanli OM, not the regular sierra om.
Edited by redwngr
I'm 5'10" or so, 160lbs...I love the seats in my '16. Had an '01 bench, '06, then '09 both with buckets...seats have gotten better with each one I think. Bench to buckets was a huge jump (improvement to me).
Mine does it, but it's only the driver headrest.
My '15 Silverado LT had the adjustable drivers headrest, this '16 SLT Sierra does not. It is fixed on the '16 but it doesnt hit my head at all, the '15 when I bought it someone had moved the headrest all the way forward and it was terrible - until I figured out how to adjust it..
Update:
I stand corrected.
The adjustable headrestraint instructions were copied from the 2016 Denali OM.
The 2016 Sierra (not denali) does NOT have this instruction.
Seems we've learned another difference between Denali and SLT.
Update:
I stand corrected.
And seeing that mine is a WT with more than a few stealer ordered options...................I don't have it.
I had my driver alerts moved by a local trim shop after the dealer refused to do it, while he had my seat out i told him about the high front and he said yes he had fixed many by adding some washers on the two rear mounting bolts so he showed me, simple fix and it helped a lot to get rid of the clam shell feeling.
I just test drove a new 2016 WT regular cab short bed. The seat had no mid to upper support and you could push your hand all the way through it. On the 5 mile test drive, I could not stand it! The seat was hurting my back and even the salesman had to agree the seat was lousy! We both tried adjusting the lower lumbar and doing everything possible, but we both could not stand the seat. Apparently, others customers had complained because he will give you the name of a local upholstery shop that will reupholster the seat for $500 that will fix the issue. I told the salesman, I can't spend a fortune on a truck, then another $500 to make it comfortable. I read online this is now the number one complaint and GM is switching seat suppliers in an effort to make a better seat. I'll just wait until the 2018 model year when the new seats comes out!
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
