Things I done to my truck for $50 and under, including things I already owned so I spent $50 or less to complete. You can check out my YouTube channel or instagram for more pics on this.
1. Wireless charging on front arm rest seat.
2. Footwell and steps lighting
3. Driver assist handle.
4. Led pods as fog lights
5. Led flush mount backup led pods
6. Grill flush mount led pods
7. Switchback leds on turn signals and leds for lights over the truck.
8. ANDROID TABLET Nexus 7 as head unit. Only needed paint for this mod, as I had extra head units and all the materials.
9. Bluetooth Steering wheel control for the nexus 7.
10. 30ft tow strap
11. Custom Decepticon under seat storage box with leds
12. EBay seat covers
Many more mods I can't think of right now, everything on the cheap.
Check out my YouTube channel and instagram @egroj_legnar
YouTube.com/jorge_dropkick_rangel
Edited by NitroDatsik
I'm looking at PlastiDipping my bowties, and still debating on doing my rims. Will I only need to clean the surfaces that I want to "dip" or do I need to rough it up?
Waymon, where did you get your phone holder? How did you get it to stay in the pocket?
It's just a suction cup window mount. I snagged it off of Groupon a few years ago. The suction part was junk so I cut it off.
To make it stay I trimmed both edges down to flat edges so they would wedge in the back of the pocket. The pocket is tapered. You just wedge it back there real good. Doesn't move or make noises. Took a day or so to settle in but it's solid now.
Cleaning it with soapy water then rubbing alcohol to remove any remaining oils. No sanding. Mines still perfect 10 months later
Just clean them and make sure they are dry. Tape them off nice and then spray light coats of plastidip. My emblem was about 8 light coats
What process did you use to install yours? I'm looking at doing two of these, definitely one, at 2x12.
Went to Lowes, had them cut it to length, and tossed it in the slots. Under $5 and 5 minutes.
I want to say it was 62 or 64 inches, can check if you need me to.
This looks like it on amazon. Hopkins SC-CHA Go Gear Console, (Charcoal) https://www.amazon.com/dp/B000FGEF64/ref=cm_sw_r_cp_api_EL4QybF298KZH
Found it on autozone: http://m.autozone.com/interior-organization-and-cargo-management/console/hopkins-console/266300_0_0?location=
Autozone is black in color. The amazon one is gray (charcoal)
you rock! Thanks!!
I had that in my 03 WT. however I screwed mine down to a piece of particle board and velcrod it to the floor.
If you are going to plastidip your rims make sure you watch a few YouTube videos and do it correctly. Make sure you put on several Coates. I bought a set of gm rims on Craigslist that had plastidipped but the guy put it on too thin. When I went to remove the plastidip so I could redo it the areas it was sprayed thin did not peel off. I had to use a pressure washer and paint thinner to get it off the rims.
I can measure it. My lower corners seem to be rounded in the bed, I may have to sand them some to get them to fit.
i cut the bottom corners at 45 degrees in order to get it to lay flat on the bed.
Edited by bndawgs
Ok so the new cap wasn't $50 but the LED license plate lights and High output LED reverse lights were under $50 and really bring the truck together. I'm not sure why GM cheaps out on the reverse & license plate bulbs when the rest of the truck is LED ?
Also please ignore the truck looking like a mess, roads are a mess here :(.
Painted hitch again. Did it at work with their paint. On the clock. [emoji1303]523c741f2f2e3eb432a2b75cb6ec54f7.jpg
  • Like 4
HA, I haven't washed mine since October. Dealership washes it for free each time I get my oil changed (Nov & last week), they do a decent job. Grabbing new headlight bulbs later this morning, watched one die about halfway to work tonight, and some LED exteriors.
Slow day at work? I may repaint all three of mine (2", 2-5/16" & Pintle). Why did you choose red?
    btm
    btm
  • Who's Online   5 Members, 0 Anonymous, 1,472 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
