After having had to replace a charcoal canister in a previously owned vehicle as a result of damage to it being caused from topping off, I'll never do that again. $600+ repair. I suggest you avoid topping off to see a round $$$ amount.
I'm having a very similar problem on my 15 Silverado, but I have noticed that using the same pumps, cause the same problem. I'm not having this problem at all pumps, but I have found this problem at various levels, not only below 1/4 tank. When I start experiencing this problem, I pull the nozzle out, reinsert it and try again. Usually, with success within 1-3 tries.
My 2015 has this problem. Since day one my truck has been a royal pain in the ass to fill up. Takes forever and constantly shuts off. I really don't want to change gas stations since the station is just yards away from my house.
Edited by Geiser100
It seems that most nozzles nowadays do not have a LOW setting the lock seems to only engage at almost full blast. Here is my CONSPIRACY THEORY this is done on purpose to makes the gas station some extra money. All pumps now have a recovery system and at full or near full flow a good bit of fuel is recovered and never makes it into your gas tank even though your are paying for it. Double wammy you are pissed off about the nozzle cutting off plus buying the same fuel over and over! These guys are BRILLIANT .
Very good point. I have and old friend who delivered fuel for many years. He got paid by the amount of fuel actually delivered. The despencing stations and pumps meter off the vapor not the actual gallons pumped. Slow fills in cool temperatures net you the most fuel for your money.
Another thing he told me was as I said he got paid for the amount of fuel delivered. So if he had a load of 2500 gallons of 87 octane and the tank only held 2400 gallons the remainder would in up in the 93 octane tank.
The vapor recovery system you are referring to is slowly being decommissioned, and is not required on new builds or when new dispensers are put in. Your theory is true tho some fuel is inadvertently pulled back into the system.
Yeah lol a long time ago they used to do that, but with the ATG and Veeder root systems reporting to corporate it's impossible to get away with. Now the mom and pop places it could happen. Also the underground storage tanks are a constant temp being underground (also monitored by the ATG and Veeder root) so temp has very little to no inpact on fill ups.
Oh crap... A new problem I didn't know I had... :ughdance:
Edited by Havvkeye
If it's less than 7 years old, the charcoal filter should be covered by the government-mandated emissions warranty.
I haven't experienced this issue with my truck yet. I had an 08 Malibu that would constantly kick a BP gas pump off no matter how much fuel was in the tank. Worked fine at all the Kwik Trips in the area.
Edited by HondaHawkGT
My local BP is the only pump I still have issues with it. The nozzle has a big rubber "spring" type shroud which if I don't hold it in my tank it pushes the pump nozzle so far out of my tank it shuts off.
It's a "safety feature". One that requires you to just barely stick the nozzle in and hold it in a precarious position.
That's apparently safer than having the nozzle fully inserted.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
