So, the PSW-8 fits in the center console and could replace the bose system? If you already had the Bose with sub, would you need the LC2i converter? Or would it run the existing subwoofer line level inputs direct from the bose sub amp to the line inputs on the Alpine?
Spoke to an engineer at JL and they are working on a 10" center console box! Not sure how they are going to do it, I imagine a 10" TW3 will be used
  • 10 months later...
Any updates on this?
Are boxes still being made?
Guessing measurements won't be released.
Just reading through here looking for ideas on the 2014 I recently bought. Here's another option I found.
https://www.ebay.com/itm/2014-to-2018-Chevy-Silverado-Crewcab-Subwoofer-Enclosure-Center-console-Hidden/362061168337?hash=item544c86fed1:g:J~oAAOSwQvhZhLS-
He has packages with sub and amp as well. Here's one, but there are a couple others.
https://www.ebay.com/itm/2014-to-2017-Chevy-Silverado-Crewcab-Subwoofer-Enclosure-Center-console-Hidden/361930098837?hash=item5444b70895:g:gbMAAOSwol5Yyzjv
On 7/12/2018 at 2:15 PM, Willie will said:
That rattle has be really annoying! What’s wrong with under the rear seats?
I use the space under the rear seat and don't want to lose it. The OP said it doesn't rattle at all.
I guess he was making and selling these boxes, but isn't any longer. I hadn't seen this thread before I found the box on ebay.
My neighbor just bought one of these setups from the guy on ebay. He installed it in his wife's tahoe. It sounds amazing and doesn't rattle. As soon as I find someone to buy my single 10" box under the rear seat I'm going to buy this setup. It sounds better than my 10 and I'll get my rear storage back.
Sent from my SM-G950U using Tapatalk
Can you post some pics of the install and before and after if you get this setup?
That's funny! I'm trying to sell a 10" myself first. lol
It's in a box I had in my 03 though.
Sent from my Pixel 2 XL using Tapatalk
I'll post some pics when I do it. Might be a awhile till someone buys my box though.
Stock bose 6” sub vs 10” JL Stealthbox for under center console
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
