New member sitting at the dealer thinking about purchasing etc...
Need to know quickly if this causes any engine issues.
I had a new 2013 Honda Pilot that was going thru 1 quart of oil every thousand miles because of this technology etc...
Thoughts?
I believe you are talking about active fuel management.It's an issue for some but that wouldn't keep me from buying a truck I like. This is my third truck with AFM and I deactivated on the first 2 my new one will be deactivated soon also. Alot of people deactivate it and end up with a much better truck also
Sent from my Nexus 6P using Tapatalk
Edited by rully1012
What issues do they typically have?
:rollin: Explain this...
They also end up using more fuel. But the big thing is they can put exhaust on it and it always sounds like a V8! Ohh :smoker:
OP, some early gen trucks with AFM (ie back in the mid 2000's) there were some occasional problems. Those have mostly been ironed out with exception to the few that have a rogue problem now and try to make it sound like a huge ordeal streaming from the original models with it blah blah blah. You should have no problem, buy it and enjoy it as well as the fuel savings that come with it.
Tyler
Tyler
Not questioning your knowledge or background. But the same way my statement might have came out a bit too "general" for your liking.
I would like to inform you that on both of my other trucks my gas milage actually increased
Don't believe me ....Get a black bear tune you might get the same results I had. And we'll the fact that exhaust sounds like a v8 throughout is an added bonus.
Never the less we agree on one thing ...OP buy the truck.
My truck was solid when it had AFM.
Just in my opinion it was better after the deactivation.
40,000 miles on mine. No problems. I never notice it.
I did find that my 5.3 runs better on 89 octane. Doesn't like 93 though
I am not 100% convinced that turning the AFM off permanently is the "BEST" solution I have a Hypertech hand held tuner that i used to set it to only come on above a certain speed. Kind of the best of both worlds.................
I happen to agree with you on that. When I tune my current truck I'm going to ask if this is possible. So that at cruise on the highway you can drop down to v4 but on all street driving you'll stay on v8
This never acured to me until I read it on another forum a month or so back
I've had the AFM turned off on my 2014 for the 30k miles I had it from new with 0 issues and on my 2016 truck with 10k miles with 0 issues. Doesn't hurt a thing at all and didn't impact my gas mileage one bit.
I have a 6.2, ordered it and towed from day 1, now has 24k on it and have 0 issues, burns 0 oil so far and i don't change oil till the truck reads 20%. Most of the time I don't even notice v4 unless i have it on my screen, but i also have factory exhaust so far. Just buy what you like, you only hear about the bad stuff i find on these forums and don't hear about the other 95% of people that are happy with there trucks.
I've got a 2017 Silverado with the 5.3. I only have a little over 300 miles on mine, but I really never even notice when it switches between V8 & V4 and back unless I happen to look at the DIC and notice it. Too early to tell about oil usage.
I had a 2007 Sierra 5.3/AFM with 92+k miles on it and it never used a drop of oil between changes. Everything was left stock on the truck from the day I bought it.....no tunes, no new exhaust etc.
I hope my 2017 fairs as well as the 2007.
I can definitely notice mine switch over. It's not as pronounced as the MSDS on the Ram that I owned, but I feel it. I think probably because if I'm light on the throttle, it will sometimes feel as though it's hesitating or trying to figure out whether to be in 4 or 8.
I'm going to add a little tidbit in here as well.
I had a 2007 Tahoe LTZ that suddenly went into limp mode and threw codes. Traction Control and Stabilitrak lights came on. I had a misfire on cylinder 1, because the intake valve was not opening.
I brought it in and they found the issue to be caused by the AFM. They said that it wore out the rockers and wore a lobe off the camshaft. They also told me this was a common problem due to the fact that you're essentially "dragging" along four cylinders when the motor goes into 4 cylinder mode.
The cost to tear down the motor was the same as to swap in a used one. This happened at 170,000 kms.
Like I said, they dealt with many of these same scenarios.
That being said, I bought a 2017 with the same feature, so obviously it didn't sway me from getting a new truck.
Perhaps this issue has been worked out in the newer generation motors?
Edited by KA0S
Can I tell it switches? Yes, but I am also extremely tuned into the vehicle. When I have wife and kids in the truck I don't even realize it anymore. Now, at 23K I am forcing myself to not even pay attention anymore. I consume no oil yet that I can measure/quantify that tells me the engine is consuming.......I would not hesitate to buy another vehicle with it at all. I also expect to achieve the same durability with engine as the previous motors without AFM/DOD or whatever it's called.
As a note: expect the new Trucks to have the even more advanced Dynamic Fuel management technology and be even more seamless! I am probably the only one these forums who is 100% happy GM is using AFM and not 6cyl turbo@!
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
