On 1/21/2020 at 2:05 PM, Chet said:
For those of us with push start, how do we keep the truck accessory mode on? It times out. We have no key to leave in the ignition. Anyone have success doing this with push button start?
read your owners manual!, it explains how to put the vehicle in accessory mode so it does not time out after 10 minutes
  • 2 months later...
To keep the Accessory in ON position for keyless vehicles, put the vehicle in service mode.  This may be the solution.  It's described in the owner's manual:
"Service Mode
This power mode is available for service and diagnostics, and to verify the proper operation of the malfunction indicator lamp as may be required for emission inspection purposes.  With the vehicle off, and the brake pedal not applied, pressing and holding the ENGINE START/STOP button for more than five seconds will place the vehicle in Service Mode. The  instruments and audio systems will operate as they do when the ignition is on, but the vehicle will not be able to be driven. The engine will not start in Service Mode. Press the ENGINE  START/STOP button again to turn the ignition off."
  • 4 weeks later...
"Service Mode
2020 Silverado with push button start - I was able to open the doors exit and lock the doors and it stayed on.  It did NOT time out and shut off after 20 minutes..  On to step 2 - rigging a charger will enough amperage to keep the battery up.  Anyone know what the amp draw is in accessory or Service Mode?  Does anyone know if the trailer maintainer in a trailer will keep the truck charged on a 2020?
Edited by Dave's Place
  • 2 months later...
Interesting thread here. Lots of good info. I’ll be boondocking in Montana where there’s no shore power or cell service so I don’t have the same goal as OP but it is good to know more about how our trucks work and can work with our campers.
Sent from the demons in my head
  • 5 months later...
I too would love to know how as well. I have a 2020 Jeep Grand Cherokee and I can use my wifi hotspot but the problem is the car has to be turned on. It works with Acc but the car automatically cuts off after about 20 minutes so I have to go out to my car and re-hit the button (push to start) again. It works great as far as service and distance but having to ruling out to the car every 20 minutes is annoying. To keep the battery charge I keep it plugged up to my camper which runs off solar. I need to know how to keep the car active without having to do this. Is there a way or a app that can help?
  • 7 months later...
So I guess I'm getting old, but when I was young we were told to never leave the car in ACC for too long as it could "burn up the ignition". Now I doubt that's still the case today, but are there any other side effects to leaving the vehicle in ACC mode? On my '20 Sierra 2500 Diesel I can hear a rather loud noise like a pump or something running in the back, and on our '19 Escalade every light in the world is on, so that's gotta be some serious battery draw and wear on the lights. Or am I wrong here?
I use my 2019 tahoe hot spot to live feed our church services. The phone signal is too weak but the vehicle hot spot works great. I just park my Tahoe close enough to my iPhone so I can connect to Facebook live feed inside the church. The only problem is in acc mode my battery runs down too quickly. I do have a/c power outside. Is there an onboard charger that would work to keep my battery charged?  Or anything else I can do to keep my battery charged.
Stoney Field Farms posted a great idea to use a 7pin trailer plug to allow a quick connector to a regular battery charger. This BatteryTender is overkill but works great. You can use about a 6amp charger/maintainer for your battery type.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 3,038 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
