Z71 Speedometer
I drive a z71 Sierra, but have always wondered why it didnt come with a z71 cluster. Is this just an extra add on when purchasing the vehicle?
I wonder this also. I have a z71 sierra and like how the chevy has that.
They only do that on the chev.
Same thing with the sill plates and logo on the fron grill.
I guess you have to get the all terrain to have that on the gauge cluster. "All Terrain" that is.
GMC owners usually can't count that high!!! Not enough fingers and toes.
It's an extra touch to help the silverado folks deal with not being Professional Grade. ☺️
Yes, Chevrolet's get the z71 cluster on all z71 trucks.
GMC's do not get z71 clusters, you have to have the all terrain package to get that faux carbon fiber look but it does not say z71 it says "all terrain" on the cluster itself.
My 12 Sierra All Terrain has the Z71 cluster. :happysad:
Certain yrs the z71 cluster and sill plates only came if you ordered the Z71 Plus pkg
Am I the only one that thinks that Z71 cluster looks ridiculous, with the fake carbon look? I'm glad they didn't put it into the GMC lol.
I have the faux carbon fiber all Terrain cluster and honestly unless you look closely or the sun hits it right it just looks black.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
