Chevy really shit the bed on this.. how much harder would it of been to implement something that worked?
See the PDF file attached below this poor quality unformatted copy/paste list which phones are supposed to fit properly and charge in our trucks. You can read on the bottom 2 paragraphs some notes and phones that don't fit due to physical size. The new Galaxy S8 fits but the S8 plus does not according to GM.
Revision: April 26, 2017 Phone Manufacturer Phone Model Built-In Wireless Charging Recommended Case / Back Cover Apple iPhone 4/4s Energizer Model: IC-IP4G Apple iPhone 5/5s Aircharge MFi Qi iPhone 5S / 5 Wireless Charging Case AIR0191 Duracell/Powermat REC000078 CHOETECH Qi Standard Wireless Charger Receiver Case for iPhone 5/5s Apple iPhone 6/6s iPhone 7 BEZALEL Latitude [Qi + PMA] Dual-Mode Universal Wireless Charging Receiver Case Aircharge MFi Qi iPhone 6S / 6 Wireless Charging Case HTC Incredible2 HTC6350-WLDR LG Nexus 4 X Built-in / Not Required LG Nexus 5 X Built-in / Not Required LG Spectrum 2 X Built-in / Not Required Motorola Droid 4 Motorola Model: MOTDRD4-WLDR Motorola Droid Bionic Motorola Model: MOTBIO-WLDR Motorola Droid Maxx X Built-in / Not Required Motorola Droid Mini X Built-in / Not Required Motorola Moto X Incipio model: MT231 Nokia Lumia 920 X Built-in / Not Required Nokia Lumia 928 X Built-in / Not Required Nokia Lumia 830 / 930 X Built-in / Not Required Nokia Lumia 950 / 950 XL X Built-in / Not Required Samsung Galaxy S3 Duracell/Powermat: REC000072 Samsung Galaxy S4 Samsung Model: EP-CI950IWK Incipio Model: SA-069-SLV; SA-069-BLK Samsung Galaxy S5 Samsung model: EP-VG900BBU Samsung model: EP-CG900IBA Samsung Galaxy S6 X Built-in / Not Required Samsung Galaxy S6 Edge X Built-in / Not Required Samsung Galaxy S8 X Built-in / Not Required
Notes: 1) If phone does not charge, remove it from charger for 3 seconds and rotate phone 180 degrees. 2) Not all phones fit into all vehicle integrations. 3) Cases used on phones with built-in wireless charging capability may have reduced performance. 4) Do not use the wireless charging system with objects between the charger and the phone. 5) Phones that are longer than 150mm (approx 6 inches) may have reduced or no performance. 6) Phones that are not listed have not been evaluated for compatibility.
Incompatible Phones Due to Physical Size: 1) Samsung Galaxy S6 Active 1) Apple iPhone 6 Plus, 7 Plus 2) Samsung Galaxy S7, S7 Active 2) Samsung Galaxy S6 Edge Plus 3) Samsung Galaxy S7 Edge 4) Samsung Galaxy S8 Plus 5) Samsung Note 5, Note 7 G
GM_Wireless_Charging_Compatible_Device (1).pdf
Do you have a case on the s8 plus?(If so which one) I'm going tomorrow for new phones and was going with the regular s8 so I can use the wireless charging feature. I know some hate it, but I like it and use it everyday on my way home.Thanks..
I have an s8+ and it works...slow speigen slim case, bottom of the phone propped up on back of the armrest.
Sent from my SM-T713 using Tapatalk
Have S8+ with a case did this quick and easy just flip the rubber part and you're good to go
I have a S7, and it charges fine in my truck....
...because I installed my own 3-coil wireless charger under the mat. :)
Ditto. Even charges in an Otterbox. Sometimes it does move off the pad though.
But I have the bench seat. I'm not sure the phone fits in the bucket seat console. I know my last phone (Note 4) didn't fit in the bucket console but did in the bench console.
I don't get what all the fuss is about charging. My Samsung s7 lasts almost 2 days. No need to charge it slowly on a wireless pad. Mine is plugged in to usb for android auto all the time anyway. Glad a few different solutions have surfaced for those with bigger phones who want the feature
The phones will charge on the charging pad, they are just too large to seat themselves in the proper spot with a case on them. I have a 2016 with the Qi pad, and it worked fine with my S7Edge and also works for my S8+. I'll try to get you a pic this evening when I leave the office.
If you angle the top bezel of the phone at downward angle with the top bezel pointing toward the front of the truck, with the bottom bezel raised outside of the pad, the phone will not slip, and it will also charge flawlessly. But, since the Qi pads aren't fast charging, I'd recommend getting you a fast travel charger and use your AC/DC jack that should also be built into your center console. I only use the wireless charger if I don' need some juice quickly. I forgot what the output rating of the pads are, but it's not very high.
I hope that makes sense.
Edited by Penywyz DaClown
Do you have more information on this?
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
