Have S8+ with a case did this quick and easy just flip the rubber part and you're good to go
This!
Edited by wingsaa
this.. Notes: 1) If phone does not charge, remove it from charger for 3 seconds and rotate phone 180 degrees.
I have the S7 with a thin case, and 2016 - mine charges 70% of the time (first try) if I use this method.
Edited by GMC-AT
I had the wireless charging in my truck i installed myself but didn't like it, so I just went on eBay ordered the fast wireless charging USB plug and it so better and faster
Has anyone made this work on their iPhones? I know there are some external coils you can stick on but not sure how well they work
I'd wait for the new iPhone 8 or whatever they are gonna call it, it will have in built in wireless charger
It will likely be proprietary, so it's doubtful it'll work with the chargers in the trucks.
Sent from my SM-G920V using Tapatalk
It should work with the trucks, from my understanding iPhone will be using the same wireless technology as Samsung, QI compatible tech stuff lol
Why would it not work with the truck?
I've got a Iphone 7 but have a mophie case on mine that handles wireless charging. The truck charger works great with it. I've enjoyed not having to deal with wires.
For the same reason an iPhone can't use the same usb cord as practically every other phone, haha.
But apparently, I was wrong. If Apple's unit is Qi it will work. Granted, the factory installed chargers seem to work less than stellar with their one coil.
I have a S7, and it charges fine in my truck....
...because I installed my own 3-coil wireless charger under the mat. :)
How did you do that?
Does anyone have an iPhone 8 with the wireless charging.  Does it work? Thanks,
Yes, works just fine. I’ve tried it in a silverado and a traverse.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
