Went to the dealer yesterday to have them install the revised 2017 module.
Didn't fix anything, same exact situation.
Will be calling GM customer care back and continuing to pursue this.
Will continue to update here.
What were the part numbers listed on the service order?
You are one patient man!  My time and aggravation is worth more than the 100 bucks I spent on the dang thing.
By the way, there is no "revised 2017 module".
Original 2017 module is part # 23248791.
Revised 2017 module that was installed under warranty is part # 84162497.
2018 module I've been requesting is part # 13521066.
The 2017 Escalade's are having the same problem and using 13521066 as their replacements as well.
http://www.cadillacforums.com/forums/cadillac-escalade-esv-forum-2015/1009889-new-iphone-8-x-wont-charge-10.html
Edited by NorCalSLT
http://gmauthority.com/blog/2017/11/general-motors-chevrolet-buick-gmc-cadillac-iphone-8-and-iphone-x-wireless-charging-compatibility/
"We dug deeper and found out that the charging pads on GM vehicles support both of the wireless charging standards: Qi and PowerMat. But it seems that GM’s implementation of Qi is not complete. Though we haven’t confirmed this, we assume that the incompatibility is the result of GM rushing the technology to market in order to be the first automaker to have cars with wireless charging. In doing so, it seems that the automaker used an early or incomplete spec of the Qi standard.
Adding some insult to injury, it doesn’t appear that this is an issue that can be fixed with a software update. Instead, it’s a hardware limitation that will live on with the vehicles forever."
Open the owners manual and you will see GMC claimed our vehicles were QI spec when sold.
They then created an approved devices list to try and cover themselves retroactively at the beginning of 2018.
GMC marketed our vehicles as Qi compatible but yet Apple has said they dont meet Qi compatibility standards.
https://support.apple.com/en-us/HT208148
"The implementations of wireless charging in 2017 and earlier models from Buick, Cadillac, Chevrolet, and GMC do not meet the requirements for Qi certification. These models do not work with iPhone X, iPhone 8, and iPhone 8 Plus. "
Class action litigation seems quite possible.
Edited by NorCalSLT
16 minutes ago, jhbrennan said:
Come on man - seriously?
Certainly, its called consumer fraud and deceptive marketing.
You claim something in order to sell a product, then it better be true.
Not many vehicles owners have the mindset or time to pursue things like this, but how great would it be if litigation resulted in all 2017 GMC owners receiving notice in the mail and getting a direct, hassle free replacement that actually works as advertised.
Its not right that so many people get screwed because no one will take the time to address a legitimate issue.
Consider that this topic has 32,000 viewings and growing and are mostly only Sierra owners, GM did this across the board on all 2017 models.
Not everyone uses forums either. How many people across the US have gotten the short end of the stick here? Alot.
Edited by NorCalSLT
Class action. Really? Come on man. Spend the hundred and save yourself the frustration and aggravation. No attorney is going to touch something with no possibility of a monster payout. To each his/her own though. Sue on my GM brother.
Edited by MRL_Sierra16
6 hours ago, Tahoe02 said:
Removed the module battery on my 2017 and it works perfect on my iphone 8, took about 10 minutes.
What "module battery"?  What did you do to get it to work?
Oh geez.  GM would find a thousand loopholes to skate around responsibility; i.e. blaming it on the phone manufacturer for changing specs, software, design, etc.  They could even claim protective cases impede the charging.  There are WAY too many variables at play here to prove GM knowingly prevented some vehicles and/or phones from charging properly.
Perhaps you'd find quicker satisfaction by setting up a GoFundMe so you can buy a module.  Hell, if all of us who've told you to buy one and move on contributes just a couple bucks, you'd have one by now! :thumbs:
Edited by lapoolboy
  • Haha 1
jhbrennan, there are directions with pictures in one of the threads but basically you open the console lid, remove the bottom cover, remove the module and open the module, remove the magnet, looks like tiny battery then reverse the procedure to put everything back together.
Edited by Tahoe02
left out magnet
54 minutes ago, Tahoe02 said:
jhbrennan, there are directions with pictures in one of the threads but basically you open the console lid, remove the bottom cover, remove the module and open the module, remove the tiny battery then reverse the procedure to put everything back together.
Thanks - but there is no tiny battery in the module...are you referring to the small magnet that sits in the middle of the coil?
Edited by jhbrennan
There is no battery. So you mean the antenna that sits on top of the magnet and coil?
A lot of people, including me, removed that and still have the same issue
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
