4 minutes ago, BlkSS said:
If you already have the full center console then you could swap the console lid with wireless charging lid and wire in the OEM wireless charging module using the power and ground from the power outlet, it just won't show you're charging on the infotainment screen and it won't be PnP as Phil (pgamboa) mentioned.
This would be perfect.  I’m not too shabby at DIY.
So you happen to have the part # of the lid with wireless charging?
I don't but you can get a VIN from a 2018 that has it and call the dealer.  @pgamboa may know as I think he may have sold one a while back.  I've seen them on Ebay too, just make sure it's for a 2018 so it'll have the updated charging module and mat too.
11 hours ago, BlkSS said:
@Stevan, just to clarify, you have the full center console and not the jump seat correct?
 I have the jump seat.
With a jump seat, the above route I mentioned won't work BUT you should be able to retrofit an aftermarket wireless charger under the mat in your jump seat lid like you previously mentioned.  Check out this YouTube video and apply the same idea to your jump seat.  There are also companies like Brandmotion that sell universal kits that with a little modification, you can install their kit.  I've never used or seen this kit in person but here is a link if you're interested.  It's not as cheap as some but it may be easier to retrofit.
https://www.crutchfield.com/p_212FDM1210/Brandmotion-FDMC-1210.html
Thanks a lot for all the help.
I think I will try and do this DIY route.  I’m thinking about ordering the cheapest wireless charger with 3 coils and charging, take it apart and put it between the rubber mat and plastic base.
On 9/13/2018 at 8:47 PM, pgamboa said:
The “kit” won’t work since your console won’t have an existing plug to “plug” it into.
I’m working on a concept for those that have a center console but not wireless charging to be able to easily add it.
Any update on adding wireless charging to a console lid without wireless charging?
On 7/26/2018 at 7:16 AM, kjohnson2289 said:
Has anyone tried charging a "phablet" sized phone like the iphone 8 plus?  GM's website says it won't fit/charge.  Curious to know if anyone has tried or has any solutions/trays/mats that would fit.  Thanks!
On 7/26/2018 at 8:47 AM, pgamboa said:
iPhone 8 Plus is too wide. I’ve heard it’ll charge but won’t sit flat.
On 7/26/2018 at 10:33 AM, razor2307 said:
8 plus will charge on the factory mat after the charger upgrade but you must place it carefully and it can’t move.  It Does sit at a slight angle.  Helps to not have a case
On 9/13/2018 at 8:02 PM, colonel00 said:
My biggest gripe with my wireless charging (came with my '18 LT that had a center console) is that it isn't a fast charger.  It's just plain slow.  Not bad for longer trips but in either situation, it's just as easy to plug the phone in. I don't suppose any of the OEM chargers are fast wireless, are they?
I have the 8+, with OtterBox Defender Case, and it sits at a slight angle, but charges way too slow.  I found one of my 4" power/data cables, from my '10 Ridgeline, and use that in the pencil holder, up front.  Downside to the wireless charger, CarPlay will not engage without USB.
Curious (don't care about the damn cat), will the phone charge faster with USB while laying on the wireless charger?
Tap into the DC outlet on the back of the center console, or the USB/DCs inside of the console?
If the lid doesn’t have the mounting studs to accommodate the module, you’ll have to get a lid that already has a module.
One thing to note, unless you’re getting a 2018 lid, you’ll need to swap the any previous version module to the 2018 module.
In my explorations on various lids, I discovered that the double white stitched lid I got that came from an SUV console had the smaller mat similar to the ones with modules. This is when I learned that GM made a “Delete Wireless” model of lids. This meant that the studs to accommodate a module were there.
See the video I made on this here.
Lastly,
I have designed a harness that will nicely pull 12V from the rear 12V cig lighter outlet for $45 that will plug into the lid with the 2018 module.
Looks like this.
One final thought on this...
I picked up a lid from an Escalade Console. My iPhone XS Max (with an Apple leather case) fits the mat! So naturally, I placed them side by side and it looks like a direct fit.
Does anyone know:
1. Is a 2019 wireless charger a fast charger?
2. Has anyone, if it is a fast charger, looked to see if it can be retrofit into a 2014+ (with or without update adapter used in 2018s)?
Thanks.
9 hours ago, GMC_SD_Ult_16 said:
Does anyone know:
Thanks.
Phil, what year is Escalade console lid? Looks like a great idea! Should be plug and play for my 2018 console?
thanks again!
I find the wireless charger pretty pointless.  Yes, it works in my '18, charging my wife's S7 Edge and my G7 ThinQ.
But it's pointless, since to use Android Auto you have to hard wire.  If I'm pulling my phone out of my pocket, I'm just going to plug it in there.  OEM's aren't offering wireless Android auto quite yet (it is available in Android, so in 2-3 years Apple CarPlay will have it and Apple Fanboi's will tell you that Apple invented it).  Once OEM's adopt the wireless Android Auto, then the wireless charging makes a lot of sense.
I had it in my last truck as a wireless charging cell phone mount, but that was so I could see the phone as it didn't have Android Auto.  That made sense - in this truck, pointless.
thanks again!
It doesn’t have the latest module.. so I’m guessing 2017. When I get time, I’ll throw the 2018 module in it and test it. I use a cable myself and a mount, so having wireless charging are for those times I just throw my phone on the lid.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 263 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
