Are my oe wheels worth anything?
Brown324
I'm a newer member and can't post in the for sale forums, I'm just considering upgrading my wheels to 22's and thought about selling my oe wheels to help offset the cost, because the oe 22's I want are very pricey, so this isn't a for sale topic in the wrong forum. I'm just wanting input, my oe wheels are the black 20" elevation wheels, there off of a 2017 with 2,000 miles on it so they're brand new and flawless and have brand new goodyears on them. Are they worth much? Could I sell them easily for let's say $1,000 with the tires to help offset the price of the 22's? I think they would cost more like $2,000 to buy new oe black 20's with tpms and new Goodyear tires so I would think it would be easy but I don't know if there's a good market for them where they would be easy to sell at a good price?
$1000 for the full set is an optimistic price, but you never know. Get them listed on craigslist. Shipping sucks, so you're better off selling them local.
There's always people looking for discounted tires. Less people who want OEM wheels, but you could get lucky. If I were you, I would list them with separate price, like $550 for the wheels, maybe $400 for the tires, or $900 for everything.
those crappy stock tires are only $600-ish brand new, so you need to discount those to move them.
If you don't mind storing them for a few weeks, you can always list high and then lower it if no one's interested. There's always a buyer at the right price. good luck.
$1000 is a fair price.
I got $1000 trade in on my factory 20s at a local wheel and tire company and sold the factory 20s off my 2012 for $1100.
  • 3 weeks later...
I saw a number of offers of four 20" "snowflake" wheels on EBay for $1799...
Brown you should be able to sell the wheels and tires for a grand. Always ask for 200-300 more than you want and be firm. Had a few lowball offers for a set of TRD 17's with less than 300 miles including tires. (450-550) 6 weeks later received a call from a nice sounding guy from Houston who was coming down to visit family and wanted wheels. I ended up getting the 900 I wanted and he was very happy because he got practically new wheels and tires.
I think it's a bit optimistic to expect anything over $1,000 for the whole set, but that's a good starting point. Who knows, you might get lucky. If someone offers you anything over $850, I'd send them down the road and be done with it!
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
