19 minutes ago, Sloverado said:
Bringing up old thread. I am looking to do this upgrade and I’m also have another question maybe someone can answer. I have a 170 amp alt and was wondering if the 84143539 220 amp would be a replacement for it? I have a 17 with the 6.2. My dealer ship wasn’t much help when asking
Id grab a real HO alt myself. Stock alts or meh.  Dc power or US alternators.   Our stock 170 atls probably only put out 100-120 amps hot.
If you just want the higher amp alternator for the dual setup I can attest you don't need it. The stock will maintain them both no problem. If you need it for another purpose please report your findings. I've had a dealer tell me changing the alternator required programming. I don't know that I believe them but with these trucks it wouldn't surprise me. On a side note I can also attest that when you accidentally run your primary battery too low to crank your truck the secondary will definitely do the job. Linked mine via the push button on my ACR and she cranked right up!
Sent from my Pixel 3 XL using Tapatalk. My build thread: http://www.gm-trucks.com/forums/index.php?/topic/192614-Tenscourts'-2016-LTZ/Z71-CCSB-4WD-Silverado
Is this the correct tray to add a second battery then? it doesn’t look to be but the the part number for my 17 doesn’t match what was on here
Edited by Sloverado
I believe you would need part number 22989633 for the correct battery tray and the tie-down
On 10/23/2018 at 3:57 PM, csoldfield said:
I can confirm 22989633 - here's it mounted in my 2017 Silverado
Super Clean Install!  Love it!
does anyone who did this have a part number listing for the dual battery cables?  Id like to do this on my 14 Denali.
If you wanna go completely factory for the second battery, it's alot of work. When i did mine, i made my own cables. The routing is totally different. I just went from + batt1 to + batt2. I also did + from alt to + batt2.  - from batt2 to engine and chassis. All of my aftermarket stereo power gets power from batt2.
Edited by RACERX7775
Add content
This just shows the breakers from batt1 to batt2.20180519_170215.thumb.jpg.58dc03ed80ef652a0f5ce6984ce2f6e5.jpg
That means you just have a bigger single battery system. Also the charge system doesn't know the difference and also you can hurt both batteries. Been there done that.
Battery tray isn't needed the factory tray works with some batteries and with Optima batteries as they come with the adapter. All you need is the hold down $7 part. I did this on my truck and posted pics.
Are both grounds going through the battery current sensor? If not youll run into high charge issues
Without a isolator then when the truck dies both batteries are dead. It will not start. Also one battery goes weak and the other will suffer. Charge system will have a hell of a time.
I wasnt looking to isolate either of them.  It was more of a way to keep voltage spikes at a min from the stereo system. This isnt my first time doing this thing.  If done right, you wont hurt anything. I had these in the back of my excursion with 2 more up front.
    smandy
    smandy
  • Who's Online   1 Member, 0 Anonymous, 523 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
