thatryan Posted August 2, 2017 Posted August 2, 2017 Took truck to dealer this morning for my link update, issues with CarPlay etc. said they updated it, but software version shows same as the pic I took last week... Sent from my iPhone using Tapatalk
DCazares Posted August 2, 2017 Posted August 2, 2017 You need to enter Developer mode to see the version of software installed. I don't remember how to get to it, it has been discussed in previous threads.
thatryan Posted August 2, 2017 Author Posted August 2, 2017 You need to enter Developer mode to see the version of software installed. I don't remember how to get to it, it has been discussed in previous threads. Ah ok so that screen has nothing to do with it? Sent from my iPhone using Tapatalk
mois93da Posted August 3, 2017 Posted August 3, 2017 Wait there's updates Available for these trucks? I haven't stepped in the dealership since they started charging me for the oil changes. Sent from my iPad using Tapatalk
roo19 Posted September 7, 2017 Posted September 7, 2017 How to update radio? My 2016 HC radio does not have "shop" icon
sk Posted September 7, 2017 Posted September 7, 2017 You need to enter Developer mode to see the version of software installed. I don't remember how to get to it, it has been discussed in previous threads. I think it's "Power", "Menu", and "Home" buttons all at the same time. Or you could try this: http://www.chevymalibuforum.com/forums/113-general-discussion-generation-9/96265-2017-7-mylink-developer-mode-access.html
Justin101714 Posted September 8, 2017 Posted September 8, 2017 You need to look at the build version, should be at the bottom of that list. That's what changes Sent from my iPhone using Tapatalk
Thomcat Posted May 10, 2018 Posted May 10, 2018 Had the MyLink screen go blank twice in 30 months - both times removing and replacing the RDO fuse cured the problem. Dealer told me to bring it in to see if there were updates of the software to cure the problem......going by the numbers on the screen alone were not sufficient to determine if it had the latest version, it had to be hooked up to their computer to determine this. Turned out the HMI module had updates, but in order for it to work properly all the modules in the MyLink needed to be also updated to insure compatibility. Screen numbers were all updated to higher numbers, eg. the Nav's 23xxxx to 84xxxx. All covered under warranty and the later free update to the '18 version of the Nav stopped the problem screen, but also saved me spending $139 - $159 for the newest Nav update to include newer streets.
ChristopherDB Posted May 11, 2018 Posted May 11, 2018 Do we know what the latest build version is? I wonder if a new 2018 Silverado has any updates?
Colossus Posted May 11, 2018 Posted May 11, 2018 By may of 2018 for a 2018 model there is probably at least 1 or 2, if not more.
56kz2slow Posted May 11, 2018 Posted May 11, 2018 Had the MyLink screen go blank twice in 30 months - both times removing and replacing the RDO fuse curedRemoving the fuse didn’t cure anything, it just made the symptoms go away until the problem reoccurs. Sent from my iPhone using Tapatalk
BigBadSierra Posted May 11, 2018 Posted May 11, 2018 They have lots of tweak updates. Mine is going in Next Friday to get the radio to stop going back to the home screen randomly.
Crstfr Posted May 11, 2018 Posted May 11, 2018 On 9/7/2017 at 12:42 PM, roo19 said: How to update radio? My 2016 HC radio does not have "shop" icon i dont think the 16's will get the "shop" icon.. only 17 and above... if i remember correctly.
Thomcat Posted May 11, 2018 Posted May 11, 2018 9 hours ago, 56kz2slow said: Removing the fuse didn’t cure anything, it just made the symptoms go away until the problem reoccurs. Sent from my iPhone using Tapatalk Yes but decided to live with it until just before the warranty expired....this way I got the newest software available for the truck which included the latest Nav upgrade so saved the cost of an updated map flash drive.
