I prefer painted. The color doesn't match the chrome.
Can i remove the chrome trim while installed on the truck? going off of memory, it's just a few tabs right?
For the handle part, you have to remove the screw at the end, and then have to slide it off, towards the rear(if it's on the truck already), not sure if the part that bends around the end will clear the smaller part. Also, the small part(other part of the handle), you have to release the tabs from inside...
Sure, no problem, but the install might not happen anytime soon. Weekends are getting busy and so is work. I just wanted to have the parts ready just in case I get an unexpected free weekend.. [emoji1]
Sent from my XT1575 using Tapatalk
No problem as I am not in a hurry to spend more money either! LOL
I didn't even know this was a thing . . . :dunno:
Oh no :banghead:
Neither did I, but my hats off to people like Phil who like to tinker and think of these things!
Thanks! I saw someone posted about these handles here and actually did. So while I was certainly not the first, I wanted to share and document my experience so that others could can also achieve this upgrade.
Wanted to share some pics on the driver side door “Keyhole Delete” when retrofitting these handles.
Thanks to @cbrsilv15 for the tip!
I left my cylinder in the base as I didn’t want to mess with the removing it. So when you remove the base, the cylinder stays in.
The worry I had was in the event of a dead battery, how I could get into the truck. Well, thanks to @cbrsilv15, he shared the process.
Pull the handle, and push the cover off to reveal the key hole. It was that easy!
https://uploads.tapatalk-cdn.com/20170924/4d37f09468d2308c95ae8809b836765f.heic
https://uploads.tapatalk-cdn.com/20170924/bcf252cb222a2637707ac76c0101cd44.heic
  • Like 7
Was it really that easy to pull off? From you video I thought you had to push up on some tabs from underneath.
Now I feel like gave bndawgs wrong info on removing the chrome trim pieces once it's already in place.. :banghead:
Just finished adding Escalade - Illuminated Door Handles. Made a "How-To" video for it. Took me about 6 hours but mainly due to recording the video.
Look the new look!
Looks great can't wait to do this. Thanks for sharing.
There are tabs underneath but when cbsilv15 shared a YouTube video of a dealer showing how to access in the case of a dead battery, I tried it and it worked.
I was wondering about that if the battery died. That's comforting to know. Now I need to decide whether to stay with chrome or try and get the tops painted.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
