This is a crazy thread no doubt. Can anyone confirm that this does not occur on the full solid window? I don't have the slide open rear window.
Yes it seems to be a problem with the connector on the sliding window. With all the opening and closing it gets worn and dirty and bent and creates a hot spot. The full solid windows have been fine as far as I know.
Thanks for the quick reply!
I Hope GM steps up and gets this resolved for all the owners that have the sliding window.
I can only imagine how that must feel when one hears that pop and sees that window shattered.
Edited by poconojoe
Not happy to report this but my full solid window shattered on me today after hearing the dreaded pop sound.
Oh, crap. Sorry to hear that. I have the full solid window also. I'm going to refrain from using the defrost. I turned off the auto defrost in the settings menu. Infotainment/settings/vehicle/climate and air quality/auto rear defog. I'm only going to use it when absolutely necessary. Then wait for a recall...
Edited by poconojoe
Anyone have a PDF copy of the recall document# N192265660
On 2/21/2018 at 10:18 PM, Paul Wojcicki said:
Good evening! Sadly this is my first post on this forum but I have lurked a bit. I own a 2017 Sierra Denali which I bought in May of 2017. I was driving today and after using my remote start to start the truck (like i do often) I drove 5 minutes and then smelled smoke. I turned around and saw smoke pouring out from behind the rear seat on the driver side. I began to freak out and pulled over to get out but about 10 seconds after I saw the smoke and began to pull over I heard a loud bang like a gunshot. I turned around and my rear driver window shattered into thousands of pieces. It stayed in place but shot a decent amount of glass inside and outside of the vehicle. I am dropping the truck off at the dealership in the morning to have this diagnosed and this is clearly something that should not of happened. I only think what would of happened if I had kids or people in the back of the truck when this took place. Very disappointed right now and want this taken care of, but figured I needed to post this on here to inform all of you about this issue. I have researched this happening and it is a common thing on some Ford f150s but I havent seen to much about GMC.20180221_155246.thumb.jpg.879f22a74290ed4f0e03ff15da7b4ffd.jpg
I had this same exact thing just happen to my 2016 high country last night. Did dealer cover this or you get any answers about this issue
Did you find any answers on this of it’s a recall won’t let me view the comments
I am still doing research. I had my rear defrost short out on my 2018 GMC Sierra HD last week. Luckily it did not shatter the window.
Dealership is telling me I'm not covered under the recall and they want $1400 out of pocket to replaced the rear window assembly.
Even my Ally Major Guard extended warranty denied the repair. Crazy.
Looking into other options. 44k on the truck.
I've reached out to GMC customer service. Waiting to hear back.
Also, does anyone know the fuse/relay location for the rear defrost. I want to pull that before things get worse.
Sent from my SM-G975U1 using Tapatalk
Fuse box under the hood, try fuse #10.
Thanks Jim,
I'll give that a look in the morning.
1 minute ago, Avolution03 said:
Thanks Jim,
You are very welcome.
Do not give up with GM, make sure you have opened a claim, and get the number, you will need it.
Really stress the point that you purchased an after market warranty from a GM dealership, and they are denying this too. Let them know you are upset, and want this to be taken care of, see how that goes.
If you start to lose traction, on this approach, start down the road of them helping you with the cost, this is when you will need help from the dealerships service manager, hope you have a good relationship with the dealer. They can do a lot more in helping you that they will let on.
It amazes me with how widely known and documented this problem is that any dealer would even try to say that you’re not covered. It went from the official recall fix being to just remove fuse #10 to actually replacing components on the window surface at the junction point where it closes. And yet some of them are still giving us a hard time about it.
I was going to try putting in a timed relay after I removed fuse 10 and then I just went thru the whole winter not once saying “jeez, I wish my rear window defogger worked”. So I’m just leaving it off. And tbh I don’t even know if I’d have any confidence in it not happening again even after the FULL fix.
The heated mirrors still work w/o the rear window so I don’t even think about it any more.
It amazes me with how widely known and documented this problem is that any dealer would even try to say that you’re not covered. It went from the official recall fox being to just remove fuse #10 to actually replacing components on the window surface at the junction point where it closes. And yet some of them are still giving us a hard time about it.
I was going to try putting in a timed relay after I removed fuse 10 and then I just went thru the whole winter not once saying “jeez, I wish my rear window defogger worked”. So I’m just leaving it off. And tbh I don’t even know if I’d ya e confidence in it not happening again even after the FULL fix.
I completely agree. It is mind-boggling why they don't include all VIN numbers in the recall.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
