Bilstein 5100's with 1/2" top spacer, 1" over rear blocks on 275/70/18 BFG's.  Bora 1.75" wheel spacers and better photos TBD.  It's my "factory offroad" creation.
Edited by Leevon
  • Like 4
15 hours ago, Leevon said:
Bilstein 5100's with 1/2" top spacer, 1" over rear blocks on 275/50/18 BFG's.  Bora 1.75" wheel spacers and better photos TBD.  It's my "factory offroad" creation.
How is the ride with the top spacer on the Bilstein's?  What setting did you put the snap ring on?  So did you get almost 2.5" total lift in the front?  This looks good, and I would like a little more lift on mine, but I have heard the Bilstein on the top notch with a spacer rides rough.
Ride is great.  I'm at the top groove, yes right at about 2.5".  I drove it with the BFG's before and after the struts and it rides better after.  The load range E tires are a little stiffer than the factory tires,  that's about all I can detect.  Actual dips, bumps, etc are smoother.
Edited by Leevon
Are sure those are 275/50R-18? That would make those tire less than 29"....
Typo, meant 275/70/18.  33.2" according to BFG's spec sheet.   I went up and fixed it for future readers, and so we can delete our posts if needed.
Edited by Leevon
Pro comp leveling kit with 22x9 snowflake replicas an 33x12.50r22 toyo mts.
That is how a Z71 should come from the factory! Super nice truck, perfect stance!
Thank you!  That's exactly what I'm going for.  I installed 1.75" BORA hub adapter/wheel spacers today and got a little rubbing to deal with.  Here's updated pics.
Edited by Leevon
  • Like 7
Got the truck leveled yesterday. 2.25 Readylift with uca. Stock wheels and tires till atleast after winter.
Thought I'd chime in here. Nothing at all special, but this is my 2017, Z71 with a 2" Southern Truck under strut leveling kit and factory wheels and tires (265's on 18's). My ultimate goal is to get some 275 70's on it, but that will have to wait until I wear out the stockers.
Leevon, the look you have achieved is my ultimate goal. That looks just right to me.  Well done!
Edited by Jason23
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
