On 3/24/2018 at 6:37 PM, Ryan_OilEngineer_TX said:
2.5” in front 3” in rear
Amp Terrain Gripper 305/55/20
How are those tires I've been looking at them and they are a great price but not too many reviews on them. Loud? Handling? Ride?
I bought my first set just to try something new and I ended up loving them. Great ride, not loud at all, and they look great. I drive a lot of miles a year highway and a ton on lease roads and I like the Amp’s better than any I’ve used before.
thanks:thumbs:
3.5" Rough Country Suspension lift with 285/55/20 Toyo Open Country R/T
Edited by Flflatsguy
  • 1 month later...
16 minutes ago, DanJS10 said:
Looks awesome! What's your setup?
2014 Silverado Z71
2.5" Rough Country Level
285/60/R20 Trail Hogs
5% All Around Tint
2.5" Rough Country Level with 1" block in the rear on 285/60/20 Kanati Trail Hogs. Either going to keep stock wheels and add 2" Bora spacers or go with 3.5" lift with aftermarket wheels. Very indecisive
Looks like it is squatting, due to the incline of the driveway.
2015 Summit White Silverado LTZ
2.5" leveling kit
Traded my 20s for 18s with 275/65/18 plus $350 cash on their end
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
