I’m toying with the idea of the same tire size but highway treads, but I only did the 1.5” Suspension Maxx on my Denali... Do you think it would clear? What’s the clearance like in yours? If not, I may get some strut spacers from SM and lift it the rest of the way just like you have.
Thanks
I do not think they would clear. Mine scrub when turning left and scrub pretty bad in reverse in either direction at 1/2 to 3/4 lock. Not to mention and undulation and turning. I’m having the 4” Fabtech lift installed this week to help. I still heard it scrubs when it flexes with this kit. We’ll see. Love the tire but it’s almost a 35” tire. Good luck to you
That’s good to know, yeah I knew it would be a heck of a stretch... Full lift it is then! I’ve seen a couple of trucks with that lift and it looks fantastic! Best of luck, and thanks for the quick reply [emoji106]
I installed the Readylift tubular upper control arms and spacers this weekend on my 18 Denali. Raised the front end 2.25" Stock rear with stock 285-45/R22 Bridgestones (for now).
Love the new stance and the ride it great.
I had intended to use another company's (suspension maxx) relocation brackets for the magneride (Readylift doesn't make one) however after installation, the thicker tubular UCA placed the ride sensors right back in the stock position. No relocation bracket needed.
I couldn't be happier with the new setup.
Sent from my BBB100-1 using Tapatalk
Just bought a 2018 GMC SLT  Z71, and was wonder if anyone has done the 3in leveling kit or 3.5in RC lift with stock wheels and 35s.. really trying to go for this look.. thanks
Wouldn’t recommend that. Spend the money on a real lift kit 4-6”. You’ll be cursing yourself for getting a cheapie “lift kit” which is just a glorified leveling kit. You’ll thank me when your not cursing ride quality and replacing front end components prematurely
Which 4in kit do you recommend without spending $1800+? Also, I have a company car so the truck may only be drivin a few times a month. Thanks..
Is anyone running the Silverado midnight edition rims on a white Silverado? I’m trying to find pictures
I wanted to keep mine looking close to stock, but a little nicer. Didn't want a big lift or big tires. This truck is my tow rig to get my SxS back and forth to the trails which includes towing through the hills of KY and TN in winter conditions. I leveled it with a 2" Rough Country kit and went with some Cooper 275/65R18 AT3 4S tires on the stock wheels. I never have more than a few hundred pounds in the bed, and my 12' tandem axle trailer with electric brakes with the SxS is only about 3000 pounds, so I didn't feel the need to go with something rated for a lot more weight than the stock tires. I think these will work well for my needs, plus they are severe snow rated which should easily cover everything we get around here.
Great thread.
I think if staying with stock tires, or real close to stock tires, 1.5” of front lift looks very good.
On 2/28/2018 at 3:03 AM, dmimbig said:
2.5" Level with 305/55/20 Cooper STT Pros
This is still my favorite truck. I'm going to try my best to imitate this look.
...wish I could trade for that color!
CST bracket lift kit
It seems the trucks without the running boards look a lot higher with a level , they all look good though !
I have a 2018 silverado.  I was considering a motofab 2.5 top strut spacer and leaving the stock 20" wheels and tires for now.  Will there be any issues?  Will the stock stamped UCA work with it?  Thanks!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
