2.25 Readylift level with Readylift upper control arms, 1.5 Readylift Add-A-Leafs 275/60/20 Nitto Terra Grapplers.9f9e9b0f94fee1e01bba5ffed7ed790f.jpg
  • Like 3
305? Are they 33 or 35 /12.50? Do they rub and/or have spacers? Looks great!
I just took off a set of 305/45r22’s and replace with stock tires and 20’s. 305’s rubbed sway bar at full lock and especially in reverse.
Looks great man. Gonna show this set up to a buddy of mine. We'll just finish installing the skid plate and gibson exhaust on his Wrangler project and we'll start planning the lift for his Silverado. Readylift seems a great choice.
Thanks man! So far I really like this setup, rides really well and gives the truck just the look I was going for, and it gets rid of the stamped steel upper control arms.
  • 2 months later...
Eibach Pro Kit [Front Coilovers & Rear Replacements]
Ready Lift UCA’s
Cooper Discoverer AT3 XLT 285/60 R20 in Stock Wheels
Rubs UCA’s lightly at full lock
Here is mine. New to me earlier this year and have been slowly getting it how I want.
Bilstein 5100 all around (top notch)
285/70R17 BFG AT KO2
Stock 17's
Ready Lift UCA’s
Sharp truck!  Curious if you put any lift blocks or add a leafs in the rear?  From the pic, it looks like a slight rake, which I like.
No sir, haven’t installed anything in the back, the picture I posted is a bit deceiving because of the angle. From the measurements I took the truck actually sits dead-nut level, and a 6ft level confirms that in multiple positions on the truck. I haven’t towed a trailer with it yet, but worry that it will be nose high with a heavy load. I am considering adding a block to get a small 3/4 - 1” rake out of it, hoping that will be enough to be level when towing.
I really like how the ride changed over stock with this system, takes bumps and washboard dirt roads much better, no more wincing going over that type of stuff, you still feel it, but the shock/spring system seems to damper the driver felt impact.
Thanks for the info!  Been really looking hard into that Eibach kit.  Between that one and the Halo Boss Kit for me right now.  Sure do like the price point on the Eibachs as compared to the Halos though.  Just wondering if the Eibach kit would be too hard of a ride.  I do a lot of highway miles and off road/farm riding as well.   Trying to find the right balance.
Installed Daystar Urethane leveling spacers this morning. I didn’t want aluminum spacers as I’ve read about creeking during turns. One of the local 4x4 shops here only installs the urethane spacers because they “just don’t get any returning customer issues when they use them”. The kit was $60 and I had all the tools already (much to my dismay)..
The kit requires cutting the factory studs and threading on stud extensions.. (locktite, washers, new nuts) everything needed for the install is included.
Stock 17's
I am glad to see someone else with the factory 17's  I have the same rims and will eventually go with the same tire size from my 265/70/17.  I like more rubber!  :)  I'm not into the skinny tire revolution.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,215 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
