My new 2018 GMC Sierra SLT premium plus Max tow crew cab standard bed
16 hours ago, 2009GMC said:
Thanks for the info. Now looking at husky and Oem mats.
Anyone have experience with oem or this seller?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F311590041810
One thing to be aware of is that the GM OEM liners don't provide coverage under the gas pedal. Living in New England with snow and salt, it was a deal breaker for me. I have the Husky X-ACT liners front liners with hump cover (since I have bench seats) and full, under the seat liner in the rear.I never looked back. They are excellent IMO
  • Replies 68
Will prob get mud flaps to limit tire spray and rock chips etc.
any mudflap recommendations?
I went with the OEM's for my 17 Silverado. I had the dealer install them at my first service appt. They're a bit pricey, but they provide good coverage and look great!
24 minutes ago, ShotgunZ71 said:
Seems like for what I do, a Max Tow may be the best bet. Definitely would go with the CC 6.5' setup, too!
The CC 6'-6" box set up has a slightly lower tow rating than the 5'-8" bed of (11,700lbs) , due to them having the same GVWR of 7600lbs.. Not sure how much you are towing for it to be a consideration...
Only thing I tow is a TT, 36', 9000 lbs in tow trim. We go 8-9 times a year and usually less than 100 miles.
I have the OEM mud flaps and I've been happy with them so far. I think they look better than the aftermarket ones I've seen. I've always hated flaps (for looks) but they sure help save the paint.
Sent from my SM-N950U using Tapatalk
In the interest of saving some $$$ and not having to buy new wheels and tires...
I think I'll put these 2012 wheels on my 2018 and put the stock 97 wheels back on the 97.
17" wheel is the smallest that will fit on a K2XX right?
If your 2012 wheels are stock don't forget they will reduce your track width by 6 mm reach side. It's not much but noticable to some people, myself included. 2014 and up are +24 backspacing where as the 2013 and older are +31. Just a FYI.
Thanks for the info. So the 2012 wheels will be recessed in the fender well more? Hmmm I guess I’ll try mounting them on the 2018 and test drive before I commit to installing TPMS sensors in them.
Just have to wait At least two weeks since my hernia surgery restricted me to 20 lbs max. The bfg k02 load range e are 58lbs + whatever the wheel weighs.
Yes as I understand it the wheels will sit inward slightly. Like maybe a total of 14 mm. Probably not a big deal, especially if you already have the wheels. I'd like to see pics of you do it because I'm looking for some stock 17" wheels and most of what I'm finding are for the GMT900's.
I thought GM changed the bolt pattern somewhere around 2010.  Or is that just the 3/4 ton and up 8 lug?
If you have a minute would you please post a pic of the rear diff cover showing the number of bolts?  I'm curious as to what rear axle is used in the max tow package.  Thanks in advance.
Nope... GM truck bolt pattern has been the same on 1/2 ton trucks since 1988 .. 6 x 5.5 (139.7mm)
On the K2xx there are 12 bolts...on the GMT-900 they have 14
So the max tow has the same axle my All Terrain has, just a different gear ratio. I thought I had read somewhere that the max tow got a stronger rear axle.  Not that it would need it, 9.5" ring gear, 33 spline semi floating axles should be plenty.  Did GM use the old 10 bolt in any of the K2xx trucks?
No, the Max tow gets the 9.76" ring gear instad of the 9.5"...lol.. yeah a 9.5" ring gear is pretty much overkill for anything a 1/2 ton can do...
I was pretty bummed that my 2018 has less cover bolts than my 2011 and it is rated higher tow
Just had to update.. GMT-900 max tow has 14 bolt rear cover and a 9.5" ring gear, 2018 Max Tow has 12 bolt rear cover and a 9.76" ring gear
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
