couple quick audio (loc) questions
I found a harness for 30 bucks shipped so  I ordered it. It came in today.   Pretty decent harness, you could make this work with pretty much any LOC or DSP with some cutting and splicing. I'll order the actual DSP in a few weeks.  I've already seen them as low as 250 bucks shipped.
  • Replies 127
What did you buy?  Link?
My chime is under control now with the AX-DSP and GMLAN09. In the Axxess DSP interface, I did select my truck for the vehicle. The chimes are better now. The only gripe I have with it is that when i signal, the front left speaker goes down in audio volume so that I can “hear” the turn signal chime. When my volume is turned up it sounds like it mutes that that channel.
2016 Silverado LT, no Amp, no Bose, IO6 Radio with 8” Screen.
where did you get it from ? i payed 63 bucks for mine but it came with a pac LOC. I need another one for my taho
I had a feeling it would work for my truck and I wouldn’t need the most.
Im having issues with my dq-61,  little bits of white noise, and occasional small whine. It’s driving me nuts. Can’t decide wether to get the dsp or the jl fix and twk.
If possible can one of you guys running the dsp look in your glove box and check the U code. It should be UQ3, UQA, or UGQ. I’m suspecting it’s UQ3. And the year of your truck?
You can get it from Bestbuy, for $30.. and the DSP is $300... not sure what you all paid... but thought I'd share the links..
https://www.bestbuy.com/site/axxess-plug-n-play-t-harness-for-select-chevy-vehicles-multi/6129318.p?skuId=6129318
https://www.bestbuy.com/site/axxess-digital-signal-processor-for-select-vehicles-multi/6129328.p?skuId=6129328
I don’t have any of those RPOs. 2016 Silverado LT 1500. Non Bose, 8” MyLink
Got mine on eBay. $30 for GMLAN09 harness and $240 for the AX-DSP.
So what codes do you have?  Do you have the io6? Can you post a picture of your rpo sticker?
Metra said if on the rpo it doesn’t say IOB then the gmlan09 should be your harness for at least 14-15
