couple quick audio (loc) questions
  • Replies 127
I think it is for 14-18 but didn’t wanna say that if I wasn’t sure. Have you called tech support at metra? If you call and ask them who knows about ax-dsp harnesses they should get you to the 1 or 2 that are pretty knowledgeable
12 hours ago, jgadget said:
i have a 17,  but it looks like pgamboa has a 16
I have a '17 with I06 and UQ3.  I'm using the GMLAN09 harness
Does anyone know if this is capable of running an active 3 way or 4 way set up?  I can't play around with the app unless  I have it installed and I don't see it in the manual online.
I wish I knew what this meant. Lol
Its going to depend on ur driver/speaker set up if u have a 3way or 4 way speaker just set it to full range or high pass ..short answer is yes .2way 3way and full or 4
I just re-read everything, again.  looks like it's just basic low pass/high pass filters.  Don't see an option of bandpass for the mid drivers.  I'll need to use a passive crossover network.  I was hoping for at least 3 way active.
What dsp/loc are u using? ..coming from ur oem stereo u will always get high lever full range UNless it has a clas d amp built in. And trucks or suvs dont have an all in one. U can set ur pass filters on ur amp if the dsp/los does not come with one
I was asking if the Axxess DSP had 3 or 4 way active crossovers.  I don't think it does.
Mmm yea great question i haven't used one yet so i dont know but let me ask my vendor tomorrow and ill let u know what he tells me .
Well crap. I didn’t even check into this. Assumed it would have a band pass. I’ve got drivers for a active setup. Silver flute Mids and seas tweets
Since I'm a huge Alpine fan I may look into thier new DSP. I know for a fact it does up to a 6 way active system. Only problem is where the hell to mount it in a regular cab.
I'm Starting to think this axxess dsp isn't all what it seems to be.  From what you guys have been saying the chime function isn't even working right which is what a lot of us are after.
I'm highly considering dropping the money on the JL fix and twk.
Whatever I use I'm going to end up just running the rear signal through it, and swap the wires for front and rear so the chimes and Bluetooth speaker will run from the left speaker up by my head. (regular cab)
