2005 Suburban Service 4WD issues
I have a 2005 Chevy Suburban that has been frustrating me with a "Service 4WD" and a "stability control system disabled".
I've been troubleshooting it for a while and I have been doing the various things that I find on the interwebs.  Some work for a while and some do nothing.
  • I removed and cleaned some grounding switches under the driver's door.  - Nothing changed.
  • I replaced the selector switch next to the steering wheel. - This seemed to work, but then the errors came back.
At this point, the drive system started randomly shifted between 2WD and 4H or 4L.
  • I assumed this meant that the encoder motor has gone bad.  I purchased and installed a new one and now I only get a red light on the selector switch.
I'm not sure if something else is wrong or if I have a bad replacement encoder motor.
I have reached out to the online parts store to see what they say and don't have an answer from them yet.
I scrolled the forums and went cross-eyed before finding a thread that talks about this.
Anyone out there that maybe has gone through the same thing and come out on the other side?
Thanks!
Bummer, your problems sounds like may others. . From my experience, these rigs have questionable electronics. It keeps the trade-ins coming in and the new rigs going out. For your situation, you could try putting the old encoder motor back in as a test. I replaced my 4x4 switch on the dash, and surprise surprise - just like yours - the problem went away for a week, then came back.
   I have other issues that are similar. Thinking about replacing the throttle body and PCM. Its kinda like throwing shit at the wall just to see what sticks.
  • 4 months later...
I too have a 2005 Suburban 4x4,mine is the flex fuel.. Anyhow at almost 180k same exact thing happened to mine. I would be driving and poof running 65mph it would engage 4 low. Or switch to Auto. There would also be times when I needed 4x4 it would not engage at all but would act like it. This truck had me so mad crazy I was ready to let it fall off a cliff.
  It spent 6 weeks at the Chevy Dealership, not a big deal they let me pick anything I wanted to drive. Big mistake for this girl.. Anyways, they checked everything from the transmission,to the rear axel.and finally the shop foreman was driving it home and poof finally engaged on its own. Turns out the issue was about 1,000 bucks to fix.. Ended up having to replace the control buttons for the 4x4 and the control module mother board for the 4x4. Now it sets at 230k and 4x4 works amazing...
 Fyi, if you just replace the buttons it will not change anything,if you just replace the mother board nothing..for some odd reason both have to be changed.
 So far most expensive repair to date. Now just to get these damn spark plug wires off and I will be extremely happy... Good luck...Hope this helps...
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
