13 hours ago, customboss said:
Hey if you need to go to the big game and don’t have tickets……find a guy with a plane and some USN SEALS TO GUIDE YOU IN.
Obviously the Liberty Mutual doofus and LiMu Emu aren't ex-Navy Seals parachutists!
  • Haha 1
  • Replies 3.3k
Top Posters In This Topic
58 minutes ago, Atlas said:
I'm so glad we have AI in our lives... 🥴
“Does anyone know what time it is?”
  • Haha 1
Grandpa The Gambler
The IRS decides to audit Grandpa, and summons him to the IRS office. The auditor was not surprised when Grandpa showed up with his attorney.
The auditor said, "Well, sir, you have an extravagant lifestyle and no full-time employment, which you explain by saying that you win money gambling. I'm not sure the IRS finds that believable."
"I'm a great gambler, and I can prove it," says Grandpa. "How about a demonstration?"
The auditor thinks for a moment and said, "Okay. Go ahead."
Grandpa says, "I'll bet you a thousand dollars that I can bite my own eye."
The auditor thinks a moment and says, "It's a bet."
Grandpa removes his glass eye and bites it. The auditor's jaw drops.
Grandpa says, "Now, I'll bet you two thousand dollars that I can bite my other eye."
Now the auditor can tell Grandpa isn't blind, so he takes the bet. Grandpa removes his dentures and bites his good eye.
The stunned auditor now realizes he has wagered and lost three grand, with Grandpa's attorney as a witness. He starts to get nervous.
"Want to go double or nothing?" Grandpa asks. "I'll bet you six thousand dollars that I can stand on one side of your desk, and pee into that wastebasket on the other side, and never get a drop anywhere in between."
The auditor, twice burned, is cautious now, but he looks carefully and decides there's no way this old guy could possibly manage that stunt, so he agrees again.
Grandpa stands beside the desk and unzips his pants, but although he strains mightily, he can't make the stream reach the wastebasket on the other side, so he ends up urinating all over the auditor's desk.
The auditor leaps with joy, realizing that he has just turned a major loss into a huge win. But Grandpa's own attorney moans and puts his head in his hands.
"Are you okay?" the auditor asks.
"Not really," says the attorney. "This morning, when Grandpa told me he'd been summoned for an audit, he bet me twenty-five thousand dollars that he could come in here and pee all over your desk and that you'd be happy about it!"
  • Haha 2
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
