  • Replies 3.3k
Top Posters In This Topic
I got in trouble last night.
My wife came home late last night and when she opened the bedroom door she saw four legs from under the blankets instead of two. She grabbed her baseball bat and started beating the covers as hard as she could.
When she was finished she went down to the kitchen to get a drink. That's where she saw me sitting reading a book. I said, "Hi darling, your parents came to visit us, so I let them stay in our room.
Did you say hello?"
  • Haha 3
On 1/15/2025 at 2:39 AM, MaverickZ71 said:
About the same as the number of pancakes it would take to paper a dog house if rowing that canoe upstream and the wheels fell off.
13 dummy. There are no bones in ice cream. :idiot:
  • Haha 1
11 minutes ago, MaverickZ71 said:
BREAKING NEWS:
The Buffalo Bills were just called for Roughing the Passer next week against Kansas City.
Pretty sure bad calls go both ways.
14 minutes ago, MaverickZ71 said:
We could, but do I want to?
 :crackup:
Is it wrong to miss points and carburetors and good old Top Loader?
  • Thanks 1
 :crackup:
Keep your friends close and your enemies closer?
Toploader? Is that a MoFoCo kind of deal, or is she the head dancer down at BigUns gentlemens club?
  • Confused 1
Top Loader is a shift I can get behind. Richmond Gear or Doug Nash have nice variations.
The M20 or M21 and BW T-10, nah. . :sick:
Okay I guess the M21 isn't all that bad.
My car has a BW Super T-10.  Funny thing is, Pontiac still used the RPO code of M21, which led some to think it was the old Rock Crusher, until they discovered it didn't whine and it shifted more smoothly.
  • Thanks 1
I just emailed myself a copy of the Constitution and Bill of Rights so the FBI, CIA, and NSA could read it.
Edited by MaverickZ71
  • Haha 1
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 436 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
