What's the next mod we all want Phil Gamboa to figure out?
May have come up with another one for Phil:
My parents just bought a 2019 Equinox.  They got an LT but the spec sheet for a Premier that was in the dealership said that an "HD Reverse Camera" was available as an upgrade.  If I can find part numbers and images I think Phil should figure out a way to wire one of these into the trucks!
More to follow ...
I’ve been dreaming of that camera since it was released. Lol. Parts are pricey though.
  • Replies 333
Dont be a girl!
  • 4 weeks later...
On 2018-12-29 at 3:05 PM, pgamboa said:
Check with @Tinkering Fox. He has a solution for that. :)
Here is a new idea for a project
look at the block heater plug on the 2020 hd where it is part of the fender .
I know this pic isn’t the 2020 HD but I’m pretty sure this badge will be on it with different engine designation or something like that...maybe somehow install the plug behind this badge and have the badge hinged or somehow able to open exposing the plug.
Okay, the last post (above) probably wasn't worth the bandwidth needed to make the post BUT I have a better idea. Now I know Phil is the master at harnesses and the entire electric road map on these trucks and that's his thing. Phil...I am begging you to look at the Air conditioning re-circulate door next time you have the dash all torn apart. It is well known GM has virtually NO re-circulate function on the K2 trucks. There is just no way this thing works properly and I don't buy the BS reasoning GM gives as to why it doesn't freaking work. I was stuck in traffic and behind a stinky a$$ Furd diesel. My re-circulate button was immediately pushed before I even got up close. After a minute being behind him I literally had to move to the next lane and get away from it. The fumes were burning my eyes and stunk up my whole interior.
PHIL- If you can somehow make a creative fix (don't know what this door even looks like) that can be done and solves this problem that would be incredible. I will even offer a bounty of $500 to a fix. The fix has to be as good as your harnesses and can't just be a temp fix. Even if I have to locally manufacture a new door, seal or whatever.
ALL others- Please don't reply with a answer like "Back off the vehicle in front", roll my windows down, get an air freshener or anything that doesn't truly fix this problem. I am looking for a no kidding fix.
This.
lol.
I'll add $500 to the pot if he can do it.
This is awesome! I’d gladly give up that for a fix, it’s really sad we have to deal with the nasty fumes that just flow right in in. I cycled my switch and other than the message on the touch screen and a slightly different sound from the air flow, there was no noticeable change in the stink.
I'll add another $500 to my original bounty...that's $1500 pledged Phil!
I second that same thing I was behind a older Chevy though lol prob 83,84 man that thing gassed me out with recirc on lol.
That’s interesting about the recirculate door. From what I can recall, the recirculate function on my 2015 Yukon works pretty well. As in, I can’t think of a time I needed it and it did not perform. I’ll have to pay attention next time to verify. I do use the Fram cabin filter that has the activated carbon, but would only expect that helps with any odors that get past.
Obviously, I’d expect the HVAC plenums to not be interchangeable. However, some time with one off an suv and a 3D printer may be the ticket@pgamboa.
You guys aren’t kidding on the recirculating air thing. My old LML was at the dealer a few times for this and they gave me hogwash answers every time. So I have just dealt with it in my L5P.
Is there a list somewhere of the harnesses that are currently offered by [mention=159655]pgamboa[/mention]?
Not yet.
Side Mirrors
Rear view mirrors
Center console
Running boards
Head lights (16+ only)
Tail lights (14-18)
Wireless charging (modules and adapter harness)
I think this is the bulk of it.
Has anyone made a 'passthrough' plug with a resistor for tail/turn incandescent to LED swaps so you don't have to splice/scotchlok the wires to install the resistor?
    d.lowrey
    d.lowrey
  • Who's Online   0 Members, 0 Anonymous, 3,596 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
