1 hour ago, Black02Silverado said:
Terry said it should be below 10.  As you can see it has never gotten that low.
Interesting. Thanks. Mine was 12 so I'll have to listen to the recordings again. Love this thread. A place to learn.
Last:
2009 Silverado
  • 24 Nov 2018
  • 75,709 miles
  • 6 quarts Quaker State Ultimate Durability 5W-30 full-synthetic motor oil
  • Last AC Delco PF48 (NOT PF48E e-core!) oil filter from my cache.
  • 9% remaining on Oil Life Monitor.
  • Also greased 2 tie rod end zerks with Valvoline full synthetic grease.
  • Tapped out AC Delco A3181C air filter.  (replace every 33k miles)
  • And did last rotation on worn out factory OEM Bridgestone Dueler A/T RH-S tires before replacing with Dueler H/L Alenza Plus in same size.
  • Uses less oil with Quaker State Ultimate Durability than it did with Pennzoil Platinum.
Next up:
2009 Silverado
  • 25 May 2019
  • estimated ~80,000 miles
  • 6 quarts new Shell Gas Truck all-mileage full-synthetic 5W-30 motor oil
  • Wix 57060 oil filter
  • estimated 0% left on OLM
  • Always grease 2 tie rod end zerks at every oil change and tap out air filter.
  • Will use Mobil1 full synthetic grease for next manual grease gun cartridge replacement.
  • Used approx. 2 quarts in between oil changes (infamous AFM oil usage problem; TSB performed, AFM turned off at 36,000 miles).  Hoping it will use even less oil with Shell Gas Truck (similar additive pack as to their diesel oil, to clean fouled piston oil control rings) than it did with Quaker State UD.
Edited by MaverickZ71
2019 Silverado CC standard bed
6.2l
2 gallons of AMSOIL OE 0w-20
PF63E oil filter
3287 total miles
64% OLM
Also changed out 3.2pints from transfer case and filled back up with AMSOIL ATL
The new squeeze package makes it so much easier.
What the E filter? I bought a PF63F for mine
Sent from my iPad using Tapatalk Pro
The F designates a case lot of the PF63. At least that's they way all our filters we purchase for our trucks. PF48F, PF63F.....that's what is on the case box
The non Ecore PF 63 filters have the lower by-pass setting.  GM went to the Ecore  when they increased the by-pass to 22psi.
Edited by Black02Silverado
Pepper 262 CID V-6
90,000 miles
5,000 OCI
6 Quarts Red Line 0W30 High Performance
Cleaned K & P oil filter
Seems the 0W20 was frothing (aerating) in the warmer weather (oil temperature over 200F) at higher RPM (above 2500 rpm). Had not been an issue until air temperatures exceeded 80 F. Not foam (water) froth (air). It would reach proper pressure then fade and/or fluctuate. SAE 30 seems to have cured this. 125 mile test run plus a few hard passes with the data system active.
Note: Absolute peak pressure difference between 0W20 and 0W30 is less than 2 psig. No surprise there. Actual 212 F vis is less than 2 cSt different.
  • 1 month later...
Pepper 262 CID V-6
95,000 miles
5K OCI
K&P filter clean 6 quarts Red Line High Performance 0W20.
Installed cooler 170 F thermostat and between the last two changes had the oil pressure checked.
It was instrument issues not oil froth so back to the W20.
For others: the 0W30 performed excellently.
2014 Terrain 2.4
95,000 miles
5K OCI
5 Quarts Red Line 0W30 and NAPA Gold filter.
5W30 Mobil 1 showed no reduction in usage. 3/4 quart in 5K.
Nick AMSOIL is up next. Need lowest NOACK.
1 minute ago, Grumpy Bear said:
6/27/2019
2014 Terrain 2.4
95,000 miles
5K OCI
The SS 5w-20 is 5.8 and the 10w-30 is 4.1 NOACK.  So the 10w-30 is the lowest in the SS line.
  • Thanks 1
  • 2 months later...
2015 Silverado RCSB 4.3
100,541 miles (5,674 OCI) Oil use zero measurable.
3 quarts 0W20 & 3 quarts 5W20. Red Line. Just working off some obsolete stock. No special brews.
Clean K&P stainless filter.
8 quarts of Red Line D6 in a drop and fill. 95.5% Red Line 4.5% AC-Delco now. 4th drop and fill. No filter change this time.
Drop and fill differential AMSOIL 75W90 Severe Gear.
Full 100K service details in my build thread.
16 minutes ago, Grumpy Bear said:
9/7/2019
Have you change plugs ??  I'm at 92,500 routing service , New Radiator w Thermostat & AC Condenser ( GM cover it ) other wise runs great .
Yes AC-Delco 41-114. .040" gap. Wires as well. It's all in my build thread.
Thank You for the info .
2014 Chevy Cruze Diesel
2.0l
4.75qts of AMSOIL DHD 5w-30
Wix WL10021 oil filter, AMSOIL does not have a filter for this vehicle.
7,416 miles on oil
84,016 total miles
0% OLM
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
