On 4/26/2020 at 8:15 PM, truck_newbie said:
Black denali grille installed with fog light bezel painted black. I wanted a black AT4 grille but there doesn't seem to be one available that supports the front camera. Anyways, i think it looks sharp.
 Deadpool would approve of the theme ?.
Hey did you have to get the fog light bezel painted or did you buy it in gloss black
Got it painted gloss black. I was going to wrap it but the wrap experienced some shipping delays so ended up getting it painted. At the time of purchase, there weren't any aftermarket bezels available. Believe me, I already checked. If you don't need it done immediately, aftermarket bezels will probably show up at some point as they did for the grille.
thanks. with the new grill has the angle of the camera changed at all. I noticed his higher up as opposed to the factory at4 grill
I haven't noticed any camera issues but i haven't really paid close attention to it. It seems to work fine, no distortion observed.
Just got the shoes put on.
20x9 +1 offset. Wanted to stay conservative this time around. Had 10 wides with a -24 on 35's on my last truck and it was getting a bit annoying. Currently running the stock tires to get a bit of use out of them. I'll get some new rubber in the fall before the winter.
Very nice.  I’m looking at that exact wheel but don’t know if I should go +1 or +20.  Can you take down the side shots to see how far outside fender?  Thanks.
Here you go. I would do the +1, there wouldn't be much of a difference from stock with the +20. There's a ton of room from the tire to the upper control arm. I could have easily went with the 20x10...but the offsets are a bit much in that width.
Edited by Trza
Very nice.  Thanks.  I think that would be perfect for me with some 33x11.50x20 ridge grapplers.
Are you leveled? Lifted? I've got a 2 inch level. Let me know how the truck rides with the Nitto's in that size. I am contemplating sizing up, but don't want to lose the comfortable ride.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
