I just did the same thing with the goo gone. It got real messy and I didn’t think I’d see the light on the other side of the tunnel. But after going through a few micro fiber towels and half a bottle of goo gone it came out good
I used to do decal work. Look up Rapid Remover. Works way better than Goo Gone.
I've got the regular single floor mats in the rear and keep getting dog hair all over the carpeting, so today I ordered the GM factory full rear floor liner. Looking forward to being able to just vacuum up the back in a matter of seconds.
This is the one most people recommend, correct? Over Weathertech and Husky?
https://accessories.chevrolet.com/product/crew-cab-second-row-interlocking-premium-all-weather-floor-liner-in-jet-black-for-at4-z71-84348198?year=2020&make=Chevrolet&model=Silverado 1500&modelId=491&body=Crew Cab Pickup&bodyId=22&wheel=Short Box&wheelId=651&trim=LT&trimId=430&drive=4WD&driveId=8&engine=3.0L L6 DIESEL&engineId=17881&bodyNumDoors=5
2 hours ago, Porterhouse said:
Washed and sealed today. Wanted to show the z71 inlay decals from a distance, it's the small things that add up....52dac03d78a1fe6100de95241da9e9b7.jpg
Sent from my Pixel 3 XL using Tapatalk
Looking good Uncle Rico!!!
  • Haha 1
After having got out with the ATV's yesterday, had to clean up today!
These came today and I put them in. The instructions say to cut the part off the would go under the fabric storage part but I  decided to keep it all one piece. The only part I had to cut was around where the jack is stored. Very easy and pleased with them!
On 6/25/2019 at 8:12 PM, OnTheReel said:
Anyone else this crazy? Added Bose emblems to the rear doors to match the factory ones in front. It kinda bugged me how bland the back door panels were. Figured it was a little thing I could do to help.
The emblems are cheap on eBay and are the same part from the K2s. Unfortunately the speaker grill holes are “fake” and not all the way through. So I cut the posts on back of the badges down to little nubs that still locate the emblem level. Then I measured to sort of match the front, made a little template and hot-glued them on. Evening boredom solved. :thumbs:
63BCC93F-6F47-49B4-8CAA-F8E92AFB64CD.thumb.jpeg.2c877f94798c1476e08bb33417403847.jpeg1DED2CD4-AE92-44C9-A143-3AADBD15F6B8.thumb.jpeg.74d968ae70c019a6f8f3bea964345b83.jpeg
Can I get the link so I can buy em, please?
  • Thanks 1
https://www.ebay.com/itm/163196550523
Just to update on that, kid kicked one of them off a few months ago. So I bought another set, pulled the door panels and drilled small holes in the grill for the posts to come through and secure them better, like the factory does up front. It’s really easy to do.
058AD38A-6C69-48F9-A7F9-2540691F486D.thumb.jpeg.87a835a70daa250d292ecbe34fa38f51.jpegDA738A99-A29D-4979-ACD0-A2945829C02F.thumb.jpeg.ee97ef345a3f90ffb5152a248b59607b.jpeg
  • Thanks 1
Quarantined means, work on the truck, lol...
Installed:
Auto Stop Eliminator - sooooo worth the money!
Jumper to allow the fog lights on with the headlights - that was really bothering me.
Blackened all the badging - still have to do the front but I ordered black and white gel coated American Flag emblems to cover the red, so waiting on that to arrive. (See pics of other emblems)
Installed grip tape on the awesome off-road side steps. (See pics)
Did you just use a diode? Care to share where it has to go or a link to directions? Thanks
I like the idea but I don’t like losing the auto high beams. I’m gonna try to figure a way to do it and keep the autoHB.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
