On 4/29/2021 at 7:53 AM, At4Life said:
2020 at4 6.2
Few changes/ upgrades:
Grill overlay
Vinyl wrapped fog light bezels
Plasti dip gmc front and rear badge
Removed "sierra" off tailgate
Swapped at4 badges and fender with black American flag badges
Bed cover
Tinted windows 5% front,  went back over the rears, sun strip windshield, and did taillights.
Readylift sst kit
Fuel Coupler 20x9 +1
Falken wildpeak at3 305/55r20
Borla atak exhaust
K&n cold air
Up next I want the Amp running boards.  And black exhaust tips
All mods look great. I love the 6.2L Flag badge.
Had the Bilstein 6112's installed up front. Added a 1" block and Bilstein 5160's in rear.
11 minutes ago, BowtieBill said:
Thanks for the link. Unfortunately, I am not an Instagram user.
I posted his website too. 0fx2gv.com
7 hours ago, AppFan said:
Swapped out the overhead console to one with homelink garage door opener.
Pics and details please?
I didn't take pics as I did it but the one on my seat is the old one. The second pic is the "new" one installed.
It was pretty simple.
1.   Pry off the 2 L shaped pieces
2.  Remove 2 screws closest to windshield
3.  Pull out old console (held in by 2 clips)
4.  Unplug 2 wire connectors and loom clip
5.  Connect wires to new console
6.  Press new console into retaining clips
7.  Reinstall screws from #2
8.  Press in trim pieces from #1
9.  Link to home garage doors
Was really easy.  It's a little odd to have the sunroof and rear window buttons that don't do anything but I like it better than the handheld remote and didn't want those options when I bought the truck.
Bought it used from car-part.com, can find on eBay sometimes as well.
6F8CBDD2-0893-4D2A-A2E4-C669F455640A.thumb.jpeg.ce1ce195d4dfaf13c97410fe27490d1e.jpeg248DEC56-ED28-441B-AE47-255A4FEBFA4F.thumb.jpeg.5e60db8c983591d13adc2700a3485cbb.jpeg
Awesome thanks! Same here so I will definitely check it out.. I have an idea for those other buttons too.. cover the logos with wrap possibly and see if I can wire them to aux lights or something else.
What is the part under? I can't find it lol
I'm guessing 84816404 but I just did a search like this pic on car-part to find it.  Was $75 + shipping. Prices vary by seller.
I’ve been holding off on doing anything to my TB for about a year but added these Go Rhino DSS sliders today. I needed something for more protection than a step and I liked these the best. I wear a size 11.5 boot and can still use them
Swapped the OE faux wood trim in the doors and center console for the GM Accessories black/faux carbon fiber ones
Hi, do you have a part number(s)?
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
