Put AMP Power Steps on my AT4 last night. Not too bad of an install and they work great. Glad I went this route and ordered without the GM fixed steps.
If you look closely you will see the Color matched door edge Guards that were just added.  I have to say I am really liking the Havana Brown Metallic color and how it changes with different light conditions!
  • Like 6
Love the color, where did you get those moldings?
Thanks, I used a Local Auto Graphics shop called ULTRA Graphics.  They did the 3M Clear on the front and the Color matched Side Moldings and door edge guards.
On 1/4/2019 at 9:57 AM, Jso21 said:
Added the Silver Chevy decal.....
How about those Tigers
Go tigers! Although I pull for the Auburn tigers. So glad y’all whooped up on Bama with them being our number 1 rival
19035DDD-8512-48CC-8C6F-2FB19D2BC5EC.thumb.jpeg.49dd54776e4b43069f9b09af806ab6b4.jpeg58B776A9-539E-482D-99D0-A991B56BAFD9.thumb.jpeg.0259132b552a1e4b41b982a36f013984.jpegD1D647B4-B585-4125-A78C-765A02F17DAC.thumb.jpeg.4b6892176882784d9c704723a5a4cf09.jpegA5D8D332-C504-4428-A293-AB3C0842CE01.thumb.jpeg.46212b59bdf2e72277765b00e1266873.jpegJust added the ceramic CTX tint to the cab and I’m happy with it. Pacific Blue AT4 with the performance exhaust and we like the extra little rumble. By “we” I mean my 3 year old son and I lol.
  • Like 9
On ‎10‎/‎6‎/‎2018 at 8:59 AM, DougFL said:
So I found a HOTT Solution to the Lack of a CD Player in the 2019 at AMAZON!
Portable CD Player, HOTT CD611 Personal Compact Disc Player with LCD Display, Stereo Earbuds and USB Charging Cable, Electronic Skip Protection Anti-S
Sold by: MonoDeals
Return eligible through Oct 29, 2018
$61.99
It has built in Skip protection, uses the USB port in the Console for power, the AUX jack for play back and the memory feature remembers the track you were listing to when you shut down the Truck!  Fits nicely on the Console tray.
 I'm adding a cassette deck to mine
  • Haha 3
Now that's Old School!  Still remember my 74 Pontiac with the 8 Track.
 My reply was my attempt at sarcasm.....  I'm sad to say I clearly remember the 8 track car deck too....
 There is something else in his photo that is old school, ….change, quarters/nickels/dimes...I haven't had that jingling in my pockets for years.
Edited by Ultra54
  • Haha 1
 I love the color but it sure is hard trying to decide on a color looking at a computer monitor. You have two pictures of the same truck yet the colors look totally different.
That’s very true. Let me try and help. The 3 pics where the color appears similar were taken on a cloudy day. The single pic that appears bright was taken on a sunny day. I can try and take additional pics Tuesday because I’ll be applying the 9h nano ceramic coat to the entire truck tomorrow.
Debadged/removed the "SIERRA" chrome plastic lettering/badging from below the red GMC logo on the tailgate of my AT4.  Trivial little change but I can't stand the way they stick stuff on these trucks.  Thinking of removing the AT4 badges as well...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
