On 2/10/2020 at 10:13 PM, NCD said:
They are the GM
factory ones. Here is a pic of mine that came with my truck. They will run you about $900 installed from the dealer.
What wheel/tire combo are you running?  They look outstanding!
That is how they should have came for almost a grand and being labeled as "sport"
Totally agree. The paint appears to be really thin, like surprisingly thin. Makes me think this set skipped a step. Bed liner would be so much more durable.
Just picked up truck on Monday from getting everything done.
- 6" BDS Lift
- 22x10 -19 Fuel Contra
- 35x12.50R22 Nitto Ridge Grappler
- Corsa Exhaust
- K&N Cold Air Intake 63-3109
Edited by burban81
  • Like 9
- 6" BDS Lift
- Corsa Exhaust
Very nice! Classy and well coordinated!
  • Like 3
- 6" BDS Lift
- Corsa Exhaust
really sharp, wow.
Thank you! 20” SCA Black widow rims on 33” ridge grapplers
- 6" BDS Lift
- Corsa Exhaust
Super clean look, diggin it! Nice city driver!
Debadged the tailgate and swapped to black lug nuts today.
Last week...
Tinted windows 20% front, 50% windshield
Lund Terrain HX steps off EBay
Bakflip MX4
Westin bed mat
Still needs more dechroming!
Edited by JME454
Typo
  • Like 3
2020 Custom 2wd
Dark lettering package. Debadged the tailgate and added the black vinyl Chevrolet graphics.
Black tri-fold tonneau cover
Black 12” antennae
Tinted windows (@25%) with 70% ceramic windshield
MotoFab leveling kit 2.5” front, 2” rear with shock extensions.
  • Like 4
Oil change and wash
e022bd8dedcb798e4e774221f02d3aa7.jpg82e4ba0a518c34185ce0bf032692b7fe.jpg782b3ab5d15d1b5085bd92056c8b9065.jpg
2 minutes ago, RyanbabZ71 said:
Oil change and wash
Nice rotofab! I have the same
Sent from my Pixel 4 XL using Tapatalk
Last week...
Bakflip MX4
Westin bed mat
Where did you buy your black lug nuts? I'm swapping to black rims soon.
Got the truck back from Xpel, with their PPF and ceramic coating! It looks great, it would look better with some sun...5f411d015272a902fb95424af761eece.jpg4ca335e6f626af32bf4431e3a72c43f0.jpg
  • Like 4
Looks super glossy !
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
